Hello everyone,
I am pretty sure that it is possible to use the navigation stack (http://wiki.ros.org/navigation) with another localization method than AMCL (http://wiki.ros.org/amcl) since I have seen that people already tried to use hector SLAM. However, I was not able to understand how they realized this "switch". Does anyone have an idea where I should start? I have been using the navigation stack with some success but wanted to try out another localization technique.
Cheers Marcus
Originally posted by Marcus on ROS Answers with karma: 164 on 2014-10-02
Comment by ingcavh on 2014-10-03:
I'm the same question about how to fusion or use AMCL and Hector_mapping
The typical Nav setup has at least three tf frames: One for the map, one for the odometry root, and one for the robot. As described on this page, the link between odom and robot usually comes from the robot's odometry, and the link between the map and the odom comes from AMCL. In order to use an alternate localization method, you just need something else that provides that transform.
Originally posted by David Lu with karma: 10932 on 2014-10-02
Comment by Marcus on 2014-10-03:
Hey David, thank you for your quick answer. I was already suspecting something like this, since I tried to run my simulation without AMCL and ros demands the transform from base_footprint to map. I was just not aware that it might be that simple. Thanks, Marcus
Comment by jamman on 2014-11-07:
Hey David, I was wondering if we can use the robot_state_publisher instead of multiple tf in Markus case ?
Comment by David Lu on 2014-11-07:
I'm not sure what you're asking. Can you open up a new question instead?
Its mostly just searching around and looking at what other people are doing, and then going and checking out that package/algorithm. I started by just looking around this forum (ros answers).
It really depends on what your system/enviornment consists of. If you want to localize yourself off laser data, but there is not always objects in the scan of your laser, you want to your gmapping_slam which uses your wheel odometry to fill in your pose estimate when there are no objects in your laser scan, or it for some reason can't match the scans.
Hector slam, however, by default uses just your laser scan data. That means that your environment has to have a good amount of objects, so that hector slam can constantly localize, or else it will crash (this should probably be fixed, and it should try to restart in my opinion, being re-initialized with your last most reliable pose estimate value).
Originally posted by l0g1x with karma: 1526 on 2014-10-02
Thanks for your answer. I was looking more into using my labs inhouse SLAM method for localization, so I will actually not need either AMCL or Hector. Anyways, your explanation helped me to understand some differences. Marcus
