When I ran a simple publisher in the tutorial (http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber%28c%2B%2B%29). I got a problem that if I ran it through launch file, the node will sleep forever. But if I ran it through rosrun [packagename] talker, it works fine. My launch file looks like this, can anyone help me?
<master auto="start"/>
<param name="use_sim_time" value="true"/>
<node pkg="hybridAstar" type="talker" name="talker" output="screen"/>
Originally posted by Min on ROS Answers with karma: 3 on 2014-09-30
The problem is
This means the uses simulation time published to /clock topic by e. g. Gazebo or a rosbag started by rosbag play --clock file.bag.
See this http://wiki.ros.org/Clock ans this http://answers.ros.org/question/193820/time-stamp-ros_info/?comment=193890#comment-193890 for info about clock and simulation time
This means your node will not spin before any other node (gazebo/rosbag) is started and publishes to /clock topic
Originally posted by Wolf with karma: 7555 on 2014-10-01
Comment by Min on 2014-10-01:
Yes, problem solved. Thanks a lot ;)
Comment by Wolf on 2014-10-01:
Plz accept answer and close thread if issue is solved...
