I am trying to write a converter from rgb to gray image
and here comes the code :
cv_bridge::CvImagePtr cv_ptr;
cv_ptr = cv_bridge::toCvCopy(img_ , enc::MONO8);
sensor_msgs::Image img2_ = cv_ptr->toImageMsg();
image_pub_.publish(img2_, *ci);
But the compiler says
/root/catkin_ws/src/usb_cam/nodes/usb_cam_node.cpp:178:51: error: conversion from ‘sensor_msgs::ImagePtr {aka boost::shared_ptr<sensor_msgs::Image_std::allocator<void > >}’ to non-scalar type ‘sensor_msgs::Image’ requested
which maybe means it cannot access the function toImageMsg() from cv_ptr
Hope anyone could help me out of this !
Originally posted by fromandto on ROS Answers with karma: 27 on 2014-09-28
Comment by fromandto on 2014-09-28:
hi administrator, I wonder if there's anything wrong with my question so it's has not been made public
The call cv_ptr->toImageMsg(); retuns you an instance of sensor_msgs::ImagePtr
See:
http://docs.ros.org/indigo/api/cv_bridge/html/c++/classcv__bridge_1_1CvImage.html#a48a7cc72fa96bdf0180d0306543ceb07
In your line
you attempt to assign the pointer to an object.
So try either:
sensor_msgs::Image img2_ = *(cv_ptr->toImageMsg());  // dereference pointer to get content before assigning to object
or:
sensor_msgs::ImagePtr img2_ = cv_ptr->toImageMsg();  //assign pointer to pointer
Originally posted by Wolf with karma: 7555 on 2014-09-29
Comment by fromandto on 2014-11-24:
Your suggestion helps alot , thx!
