Hi.
I have an anoying issue that I can't get solved...
To test debian building and releasing, I created two repos on github. One for source and the other for the release debians. I commited two of our nodes for testing purpose before trying to use our internal git and build in local instead of on the ros buildfarm... So I try to take it small steps after small steps to try to control all the aspects...
So, I'm compiling perfectly well the packages with catkin_make
and catkin_make install
in 'devel' overlay.
The install folder can be relocated anywhere and executes the nodes smoothly when I update the bashrc to source the correct folder as overlay etc...
So all seems pretty clean to me.
I do run catkin_generate_changelog
and catkin_prepare_release
still in the 'devel' overlay.
BUT.
When running bloom-release --rosdistro hydro --track hydro https://github.com/repo/repo.git --edit
in the 'devel' overlay, I have the following error:
==> git-bloom-generate -y rosdebian --prefix release/hydro hydro -i 0
Generating source debs for the packages: ['deburring_riveting_demo', 'hironx_grippers']
Debian Incremental Version: 0
Debian Distributions: ['precise', 'quantal', 'raring']
Releasing for rosdistro: hydro
Placing debian template files into 'debian/hydro/deburring_riveting_demo' branch.
==> Placing templates files in the 'debian' folder.
Running 'rosdep update'...
#### Generating 'precise' debian for package 'deburring_riveting_demo' at version '0.0.2-0'
Generating debian for precise...
No homepage set, defaulting to ''
Could not resolve rosdep key 'rospkg'
Try to resolve the problem with rosdep and then continue.
So Yes, my python package 'deburring_riveting_demo' imports rospkg.
And in package.xml
I added <run_depend>python-rospkg</run_depend>
Also tried to add it also in <build_depend>, but didn't change anything...
So as discussed on some other questions, I did clean my rosdep files and updated them.
And I also run rosdep resolve python-rospkg
correctly since it answers
#apt
python-rospkg
I have to mention that at the beginning I did try in package.xml
to < -depend> on rospkg
instead of python-rospkg
That might be one of the origins of bloom trying to rosdep rospkg??
So I have no clue about how to solve this issue...
I'm guessing that there might have a cache somewhere still pointing to <run_depend>rospkg</run_depend>
But I deleted my /devel, /build and /install; I deleted all temporary files in /src, I double checked the correctness of the upstream git repo...
Is there anywhere else I have to look for this??
Any idea of what is going wrong?
Thanks Damien
Originally posted by Damien on ROS Answers with karma: 203 on 2014-09-24
Comment by 130s on 2014-09-24:
I had the same issue before. Double/Triple-check like this might help: $ grep -r ">rospkg" $YOUR_CATKIN_WS$
