I use following launch file to run hector mapping on turtlebot. It don't gives any error also don't create any map. When I enter rosrun map_server map_saver -f ~/mymap mymap.pgm is light gray image.
Original launch file
<launch>
  <include file="$(find turtlebot_gazebo)/launch/turtlebot_empty_world.launch" />
  <include file="$(find hector_mapping)/launch/mapping_default.launch">
    <arg name="pub_map_odom_transform" value="true" />
    <arg name="base_frame" value="base_footprint" />
    <arg name="odom_frame" value="odom" />
  </include>
  <include file="$(find hector_geotiff)/launch/geotiff_mapper.launch">
    <arg name="trajectory_publish_rate" value="4" />
  </include>
  <node pkg="hector_pose_estimation" type="pose_estimation" name="hector_pose_estimation" output="screen" />
  <include file="$(find turtlebot_rviz_launchers)/launch/view_robot.launch" />
</launch>
Graph of this launch file is like this. I couldn't find the problem. rqt_graph rqt_graph
tf view_frames tf view_frames
Latest launch file
<launch>
        <arg name="pub_map_odom_transform" value="false" />
    </include>
    </include>
    <node pkg="tf" type="static_transform_publisher" name="odom_to_map" args="0 0 0 0 0 0 /map /odom 100"/>
</launch>
Bag file with /scan and /tf topics
All of the sollutions are merged as a package at Github
Originally posted by serdar on ROS Answers with karma: 3 on 2014-09-21
Comment by bvbdort on 2014-09-21:
cross check laser is published in base_footprint frame.
Comment by serdar on 2014-09-22:
@bvbdort Is it wrong that laserscan_nodelet_manager is publishing scan? In rviz I can see laser scan in /scan topic.
Comment by bvbdort on 2014-09-22:
check the frame id of laser scan it should be base_footprint or any other frame which has tf with base_footprint. Can you share your rosrun tf view_frames output.
@bvbdort I added rosrun tf view_frames output to question body.
what is the frame id of laser; you can view it from rostopic echo /scan
Also use
@bvbdort frame id of scan is /camera_depth_frame.
use <arg name="pub_map_odom_transform" value="false"/> , hope it works
@bvbdort When I pass false to pub_map_odom_transform, in rviz Transform status section it prints No transform from [map] to [base_footprint].
Change frame in rviz to map to view map
I always change but it always shows light gray square, never draws map.
and add static tf between /map and /odom in your .launch file
Edit :
remove running hector_pose_estimation from launch file. Pose not required for hector slam.
Originally posted by bvbdort with karma: 3034 on 2014-09-22
Comment by serdar on 2014-09-23:
Now map rotates with movement but map is empty again.
I added latest launch file to question. It is not working.
Comment by bvbdort on 2014-09-23:
can you share your bag file with /tf and /scan topics
I added bag file to question.
Comment by bvbdort on 2014-09-24:
@serdar i am able to see the map screen shot here but it was not proper. I used default launch file tutorial.launch in hector_slam_launch . try moving view_robot.launch before maping.launch
Comment by serdar on 2014-09-25:
I don't know what problem is. First I run rosbag play hector_mapping_turtlebot.bag then roslaunch hector_slam_launch tutorial.launch. When rviz opens I add map from by topic section. There is no error but, there is no map.
Comment by bvbdort on 2014-09-25:
first run roslaunch hector_slam_launch tutorial.launch and then rosbag play hector_mapping_turtlebot.bag --clock
@bvbdort Thanks. I see some inaccurate map. Did you have any idea what is problem and why I cannot generate map from my launch file?
Issue might be with low laser frequency fr your bag its around 10hz, but hector slam need around 40 hz. Did you try with first mapping.launch and later robot.launch ?
It didn't make any difference.
try removing args from launch file
i didnt see any problem in launch file. Can you update current frames.pdf and rqt_graph in question.
I updated rqt_graph and framed.pdf.
Comment by Stefan Kohlbrecher on 2014-09-26:
Note that running hector_mapping with simulated laserscans from Kinect is probably not going to work very well (see also http://answers.ros.org/question/33933/kinect-doing-hector-slam/)
Comment by serdar on 2014-09-26:
@Stefan Kohlbrecher Thanks. I can try it with another robot. Do you have any suggestion for robot on gazebo ?
Well, if you´re only in Gazebo, you can easily install a (simulated) LIDAR on your robot :)
Your turtlebot on github worked. Thanks.
Comment by bvbdort on 2014-09-27:
did your map worked finally ?
Comment by serdar on 2014-09-28:
@bvbdort Turtlebot at this link worked. With laser it worked. But it moves autonomously. I am trying to figure out what is causing it. Teleop isn't working. After that I will post proper launch file. Thanks for your support.
