I want to use webcamera to test images in ROS. I am programming using OPENCV and want to see the live video stream from my laptop in a window on ROS. When I try to launch a file whose contents are given below, I get an error that "ERROR: cannot launch node of type [uvc_cam/uvc_cam_node]: can't locate node [uvc_cam_node] in package [uvc_cam] No processes to monitor :". I launch the file using the command : roslaunch ishan_vision uvc_cam.launch device:=/dev/video0
uvc_cam.launch file :
<node name="uvc_cam_node" pkg="uvc_cam" type="uvc_cam_node" output="screen">
    <remap from="camera/image_raw" to="camera/rgb/image_color" />
    <param name="device" value="$(arg device)" />
    <param name="width" value="320" />
    <param name="height" value="240" />
    <param name="frame_rate" value="20" />
    <param name="exposure" value="0" />
    <param name="gain" value="100" />
</node>
Can anybody please help?
Thanks
Originally posted by ish45 on ROS Answers with karma: 151 on 2014-09-20
It looks like roslaunch can't find the node, which shouldn't happen if you've:
  • installed uvc_camera sudo apt-get install ros-<distro>-uvc-camera
  • sourced your ros installation source /opt/ros/<distro>/setup.bash
Originally posted by paulbovbel with karma: 4518 on 2014-09-20
Comment by ish45 on 2014-09-21:
Thanks a lot. Now, its working. I did not install the uvc camera thats why it was giving the error. Thanks.
Comment by arzo on 2015-03-20:
sudo apt-get install ros-`rosversion -d`-uvc-camera is shorter version
Comment by aaditya_saraiya on 2017-08-24:
Dear Sir,
I have installed uvc-camera and have even sourced my ros installation. However still roslaunch is unable to find the launch file.
Using ROS Kinetic
Try uvc_camera instead of uvc_cam and uvc_camera_node instead of uvc_cam_node
Also you can test your webcam with: guvcview
Originally posted by jseal with karma: 258 on 2014-09-20
Comment by eskay on 2018-01-17:
thanks...it worked
Comment by dolphinlove on 2018-06-30:
Thank you! Using guvcview works for me!
