Hi,
I have a point cloud which was obtained from Laser scanning. I need to extract depth images from this point cloud. I want to assume random camera position and set up some camera parameters and get images corresponding to these positions. I found some documentation but this isn't what I need : http://wiki.ros.org/pcl_ros/Tutorials/CloudToImage. There was a discussion which looked similar to mine here : http://www.pcl-users.org/get-a-2d-depth-image-from-the-pointcloud-td2795083.html but the links posted here are not valid. Can anybody help me by telling how I should get started with this and also if this is possible.
Thanks
Originally posted by Banu Muthukumar on ROS Answers with karma: 1 on 2014-09-14
PCL´s RangeImagePlanar class provides what you request (essentially rendering a pinhole camera model image for unorganized point cloud data from novel viewpoints). Specifically, the createFromPointCloudWithFixedSize is the correct method to use. Once you have converted your cloud to the PCL format, this should work.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2014-09-14
Comment by Petros ADLATUS on 2022-03-31:
links are down
