I am trying to follow ros tutorial (make a map and navigate it). However each time I tried to use gazebo and RViz, it crushes. Please guide me how to solve the problem? Is the problem related to graphics card? My machine is using nvidia driver (NVIDIA Corporation G92 [GeForce 9800 GT] (rev a2) (prog-if 00 [VGA controller])
Thank you
Originally posted by Ahyan on ROS Answers with karma: 1 on 2014-09-05
Comment by Ahyan on 2014-09-05:
However I successfully finished the tutorial 'Explore the Gazebo world'.
Comment by BennyRe on 2014-09-05:
Any error messages or something like that would be very helpful. What crashes? Gazebo or RViz?
Comment by Ahyan on 2014-09-07:
thanks a lot for your response. When I tried the following RViz seems trying to start but fails.
$ roslaunch turtlebot_rviz_launchers view_navigation.launch I need to restart my computer then. Why this is happening?
Comment by BennyRe on 2014-09-07:
Can you run RViz alone? try $ rosrun rviz rviz
Comment by Ahyan on 2014-09-11:
yes. I can run RViz alone. Also gazebo.
Comment by BennyRe on 2014-09-11:
Please post the link to your tutorial.
Here it is: http://wiki.ros.org/turtlebot_simulator/Tutorials/hydro/Make%20a%20map%20and%20navigate%20with%20it
Ok try the following: Follow the tutorial till you come to the RViz point. Then start RViz with $ rosrun rviz rviz Then you can try adding the plugins by yourself and maybe you find the plugin that makes problems. Add the plugins you see in the picture in the tutorial.
Does it crush immediatly?
Check your model files (.stl .urdf .xml), because if they are wrong RViz crashs immediatly and you never get any information about that. If you downloaded the .stl files from the repositories pay attention that right click with the mouse "save as" will download the html page and not the file
Regards
Originally posted by Andromeda with karma: 893 on 2014-09-05
Yes it crushes immediately. RViz seems trying to start but fails. I am new to ROS. I am using turtlebot in simulation. Thanks a lot for your reply.
