-- +++ processing catkin package: 'tf' -- ==> add_subdirectory(geometry/tf) CMake Error at /opt/ros/hydro/share/catkin/cmake/catkinConfig.cmake:72 (find_package): Could not find a configuration file for package angles.
Set angles_DIR to the directory containing a CMake configuration file for angles. The file will have one of the following names:
anglesConfig.cmake
angles-config.cmake
Call Stack (most recent call first): geometry/tf/CMakeLists.txt:7 (find_package)
-- tf: 1 messages, 1 services -- +++ processing catkin package: 'tf_conversions' -- ==> add_subdirectory(geometry/tf_conversions) -- Eigen found (include: /usr/include/eigen3) -- Configuring incomplete, errors occurred! make: *** [cmake_check_build_system] Error 1 Invoking "make cmake_check_build_system" failed ubuntu@ubuntu-armhf:~/catkin_ws$ sudo aptitude install ros-hydro-tf No candidate version found for ros-hydro-tf
I have a working version on BBB where I see both tf and tf2* in /opt/ros/hydro/share. I have a non working version with no tf in share. how do I build or install tf so it either get's to share or is built in a catkin workspace? I have geometry built in the carkin workspace - and it list tf as being there.
Originally posted by DrBot on ROS Answers with karma: 147 on 2014-09-02
Comment by tfoote on 2014-09-02:
As of hydro tf uses tf2 under the hood. There should be no conflict between them.
The cmake error you posed indicates that you don't have the angles package installed. Have you tried installing it?
sudo apt-get install ros-hydro-angles
More generally, if you have a workspace where the dependencies may be missing, you can usually install them with rosdep:
rosdep install --from-paths src -i
Originally posted by ahendrix with karma: 47576 on 2014-09-02
Post score: 4
Comment by kaanoguzhan on 2020-05-27:
Thank you !! I wish your more general option would be mentioned on more places !
I guess even in 6 years this important info is still missing from many places
