Hello! I'm wondering how to automatically refresh the global costmap visualization on Rviz. The problem is: I have an initial global costmap and I add an obstacle in gazebo. At this point the global costmap in Rviz should update, but it doesn't. Is there any refresh option? I'm sure that at low level the global costmap is updating since if I disable and then enable the global costmap button, Rviz visualize the new costmap.
Originally posted by alex920a on ROS Answers with karma: 35 on 2014-08-29
Comment by David Lu on 2014-08-29:
What topics are you subscribing to? What ROS distro?
Comment by alex920a on 2014-08-29:
I'm subscribing I'm rvizto /move_base/global_costmap/costmap and I'm using ros hydro in Ubuntu 12.04lts
It should be updating then. I'm not sure what the error is.
Comment by alex920a on 2014-08-30:
The error is that in Rviz it's not updating the global costmap but ramains the old one. If I disable and enable angain the costmap in Rviz it visualize. I don't want to do this trick every time but I want that Rviz does it automatically
Comment by fherrero on 2014-09-01:
The costmap_2d has a parameter called publish_frequency (default: 0.0)
Comment by alex920a on 2014-09-03:
yes! There was the default value! I simply changed it to 5.0 and it works! Thanks a lot :)
Comment by David Lu on 2014-09-03:
Good call Fernando.
Originally posted by fherrero with karma: 738 on 2014-09-05
Post score: 4
