Hello,
I am using Gazebo with ROS. I created a model in Gazebo that I was able to successfully send service calls to (to get a joint to spin for example). Specifically, I used the srv file gazebo_msgs/ApplyJointEffort (with a serviceClient node). What I'm trying to do now is get the nodes to be publisher/subscription-based to match another structure I am working with. Is it possible to create my own msg file based off of the gazebo_msgs/ApplyJointEffort srv in order to make a publisher node and still an effort on a joint? I tried doing just that and the publishing happens but there is no response to the model in gazebo. I'm obviously uncertain as to how the gazebo_ros package communication exactly works so any help would be appreciated.
Thank you
Originally posted by nbanyk on ROS Answers with karma: 40 on 2014-08-28
Comment by nbanyk on 2014-09-02:
is this question more suited for the Gazebo forum?
