In the source files (https://github.com/ros/catkin branch: groovy-devel), a bug is fixed, that is not in the PPA repository for Ubuntu 12.04 (https://github.com/ros/rosdistro/pull/5328). I would like to install the new version from the source code like described here: http://wiki.ros.org/catkin .
When I do "make install", catkin is installed to /usr/local/bin and /usr/local/share. But in ROS, still the catkin binaries from /opt/ros/groovy/bin seem to be used, the problem remains. Manually copying the files to /opt/ros did not work either. Could you explain step by step, how to install catkin from source?
Thanks and Regards, Moritz
Originally posted by baxter.irt on ROS Answers with karma: 13 on 2014-08-25
You want to use the CMAKE_INSTALL_PREFIX Documentation: http://www.cmake.org/cmake/help/v2.8.8/cmake.html#variable%3aCMAKE_INSTALL_PREFIX
Related stack overflow posts: https://stackoverflow.com/questions/6003374/what-is-cmake-equivalent-of-configure-prefix-dir-make-all-install and https://stackoverflow.com/questions/6241922/how-to-use-cmake-install-prefix
Originally posted by tfoote with karma: 58457 on 2014-08-25
Comment by baxter.irt on 2014-08-26:
Thanks, it worked. Unfortunately it did not solve the targeted bug, but this is another topic.
mkdir ~/catkin-download
cd ~/catkin-download
git clone https://github.com/ros/catkin --branch groovy-devel
cd catkin
cmake -DCMAKE_INSTALL_PREFIX=/opt/ros/groovy ./
make
sudo make install
