I am getting an error from the linker when I attempt to run catkin_make run_tests_my_package`
The error I get is: /usr/bin/ld: cannot find -lmy_package collect2: error: ld returned 1 exit status
Under testing in my CMakelist.txt I have the following: catkin_add_gtest(${PROJECT_NAME}-test test/utest.cpp) if(TARGET ${PROJECT_NAME}-test) target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME}) endif()
include_directories(include ${catkin_INCLUDE_DIRS})
Am I missing something? do I need to use add_executable in my CMakelist.txt?
Another thing to mention is my workspace layout, it's arranged as follows: my_package/ bin/ build/ src/ my_class.h my_class.cpp test/ utest.cpp world/ CMakelist.txt
and inside utext.cpp I am referencing my_class.h list this #include "my_package/my_class.h
Full CMakelist.txt
Originally posted by Kurt on ROS Answers with karma: 1 on 2014-08-21
The linker is complaining that my_package is not a library. Do you create a library named my_package in your CMakeLists.txt? (Including your FULL CMakeLists.txt would be useful here).
Originally posted by ahendrix with karma: 47576 on 2014-08-21
Comment by Kurt on 2014-08-21:
Yeah, I'm not actually including a cpp, was just a typo. I don't think I am creating a library called my_package in my CMakelist.txt. Here is the full CMakelist.txt
Comment by ahendrix on 2014-08-21:
Wow... there's some unusual bits in there. If you're trying to write a test which tests the ActorLibrary, you should probably be linking it against the ActorLibrary in the same way that you link your primary executable.
Cool that seems to have worked, I've managed to build and the the tests by modifying the target_link_libraries to this target_link_libraries(${PROJECT_NAME}-test ActorLibrary ${catkin_LIBRARIES})
