While doing the example of Service and Client from this page, I am getting an error "Import Command not Found" when trying to run the Server and the Client Nodes. I have checked the code but evrything is acoording to the tutorial. Can somebody please help? I am doing these examples using rospy.
http://wiki.ros.org/ROS/Tutorials/WritingServiceClient%28python%29
The file is as below :
#!/usr/bin/env python
import rospy
from beginner_tutorials.srv import *
def handle_add_two_ints(req):
  print "Returning [%s + %s = %s]"%(req.a, req.b, (req.a + req.b))
  return AddTwoIntsResponse(req.a + req.b)
def add_two_ints_server():
  rospy.init_node('add_two_ints_server')
  s = rospy.Service('add_two_ints', AddTwoInts, handle_add_two_ints)
  print "Ready to add two ints."
  rospy.spin()
if __name__ == "__main__":
Originally posted by ish45 on ROS Answers with karma: 151 on 2014-08-21
Comment by ish45 on 2014-08-21:
Yes. I have run catkin_make and source devel/setup.bash. Infact, I have been able to sucessfully run the publish, subscribe messages tutorial in python. So, I guess python has been set up properly.
Edit : python filename.py as suggested by one of the users has worked without any errors.
Have you remembered to do a catkin_make, then source devel/setup.bash before running the examples?
Without the proper environment setup, Python is not going to be able to find the ROS imports.
Edit:
Right. Two things: please don't use answers to answer someone else's answer (:)). Use comments for that. Also: please update your original question with the contents of the file you are trying to run (please use formatting for that: indent every line with 4 spaces).
Lastly: searching for Import Command not Found shows a lot of pages recommending me to make sure I have #!/usr/bin/env python at the top of my file. Do you? The error is probably really import: command not found, right?
Edit2: I've fixed the formatting a bit.
  1. Can you confirm that your file is exactly like this?
  2. How do you exactly run your node?
  3. Have you made your file executable (ie: chmod +x filename.py)?
  4. What is the output if you do python filename.py (change filename.py to the actual name)
  5. Did you by any chance create the file in Windows (running Ubuntu in a VM)? If so, could you try fromdos filename.py and see if the console output changes?
Originally posted by gvdhoorn with karma: 86574 on 2014-08-21
Yes, I have added that line at the top of the file as you can see. But, it is still giving the error. The error is "Import: Command Not Found". Don't know what is missing.
Comment by gvdhoorn on 2014-08-21:
Are the line numbers also in your file? Those are not supposed to be there. Please make sure the question contains a direct copy/paste from the file you are trying to execute.
No. The line numbers are not there in the file.
Thanks. python filename.py command has worked. Strangely, rosrun did not seem to be running. Thanks again.
Could you answer all 5 questions please? The fact that python filename.py worked is just an indication that something isn't right with your file, and it is most likely the shebang line (the #!/usr/bin/env python).
Comment by ish45 on 2014-08-21:\
  1. Yes the file is exactly like this
  2. rosrun [package name] [executablefile.py]
  3. Yes I have run chmod +x filename.py
  4. Yes, I have ubuntu installed on VB. fromdos filename.py does not seem to do anything. No output.
But did you use a windows editor to create the file (via a shared folder fi)? fromdos filename.py is not supposed to give any output. It converts line-endings from DOS/Windows files into Unix line-endings. Could you now (after having done fromdos filename.py) try just doing ./filename.py now, or even rosrun pkg filename.py?
