We have a system without an option to connect to the internet. Is there any way to install ROS from a CD or pendrive?
Originally posted by robospace on ROS Answers with karma: 23 on 2014-08-20
Use this command to download the .deb package:
sudo apt-get -d install "package"
And then, you should found this package in: "/var/cache/apt/archives/"
Now you can install the package with:
sudo dpkg -i /path/to/file.deb
Originally posted by Bastbeat with karma: 131 on 2014-08-20
Comment by robospace on 2014-08-23:
Thanks for the answer. I have installed the ROS hydro using the command sudo apt-get install ros-hydro-desktop-full and i have a lot of ros related .deb files in :"/var/cache/apt/archives/". Does the -d option in sudo apt-get -d install "package" makes it as a single .deb file?
Comment by Bastbeat on 2014-08-23:
Maybe this can help you http://askubuntu.com/questions/59094/create-final-deb-file-from-multiple-deb-files
