Can anybody tell which command to use to edit a package.xml file in ROS Hydro? Using the command cat package.xml, I can view the package.xml file but I am unable to edit the file. Can anybody help please?
Originally posted by ish45 on ROS Answers with karma: 151 on 2014-08-19
Comment by Bhargav on 2014-08-19:
Which OS are you using? If its ubuntu then use a text editor with sudo command prefixed to it.
sudo gedit .....yourfilename....
Comment by dornhege on 2014-08-19:
Do NOT use sudo to edit package.xml files. It is unnecessary and will mess up permissions.
Please choose a meaningful title that shortly states what the question is about.
Comment by Mehdi. on 2014-08-20:
gedit package.xml
3 Answers 3
Thanks to all. gedit is working for me now.
Originally posted by ish45 with karma: 151 on 2014-08-20
Comment by Moda on 2014-08-20:
Try to carefully read and follow the tutorial before making something else. And do not change the package.xml, before being sure to know what you are doing
Comment by tfoote on 2014-08-20:
Please accept an answer using the checkbox at the left of each answer so others know that this question has been solved in the future.
vi package.xml
vi or vim works. vim is just extension to vi.
Comment by l0g1x on 2014-08-19:
wait are you trying to edit a system ros package.xml file? If so, it is highly recommended you do not do so, unless you REALLY, REALLY, know what your doing.
Any text editor will work. Ubuntu comes with gedit and nano preinstalled.
