Is that possible? If I launch an rqt node with tag that does not appear to work... Is it supposed to?
Update with respect to @Dirk Thomas Comment:
Basically, I wanted an image_viewer with a fixed topic (for later adding some fancy overlays and so on...). I took the rqt_image_view (indeed C++!) as start point removed the topic spinner and related functions and subscribed the image_transport from a fixed topic. Works perfectly if the "hard-coded" topic exists. However, I did not manage to remap the topic in a launch file.
So far i tried 2 things (Both work with "hard-coded" topic but not with remap):
  1. Remapping in launch file using the phyton script for stand alone launching my_plugin:
    #!/usr/bin/env python
    import sys
    from rqt_gui.main import Main
    main = Main() sys.exit(main.main(sys.argv, standalone='my_plugin'))
Launch file:
<launch>
  <node name="my_plugin" pkg="my_plugin" type="my_plugin" >
    <remap from="/input_topic" to="/camera/image_raw"/>
  </node>
</launch>
  1. Remapping for rqt_gui and load my_plugin into rqt_gui
Edit 28.08.2014: Anyone?
Originally posted by Wolf on ROS Answers with karma: 7555 on 2014-08-19
Comment by Dirk Thomas on 2014-08-19:
I should be possible but with the limitation that since all plugins share the same node there can only be a single global remapping. May be it does not work correctly for C++ plugins? What exactly are you trying to do?
Comment by Wolf on 2014-08-29:
Okay, thank you! I'll have a look at that...
As mentioned before It might simply be that this feature is not implemented for the C++ plugins. You could fill a feature request at https://github.com/ros-visualization/rqt (or might even consider providing a patch to implement it).
Originally posted by Dirk Thomas with karma: 16276 on 2014-08-28
