Hello, I'm currently trying to set up a GPS receiver and base station my boss purchased to work in ROS. It is a trimble Ag GPS 542 GNSS receiver ( http://ssmgps.com/pdf/AGPB_AgGPS542_B... ). It looks like the deivce can work in NMEA-0183 sentences, and thus that it should be compatible with the nmea_navsat_driver ROS package, found here: http://wiki.ros.org/nmea_navsat_driver , but I am encountering some installation issues.
I have extracted the package into my catkin_ws/src directory using
 git clone https://github.com/ros-drivers/nmea_navsat_driver
Then I run catkin_make, and get the following response:
CMake Error at /opt/ros/hydro/share/catkin/cmake/catkinConfig.cmake:75 (find_package): Could not find a configuration file for package roslint.
Set roslint_DIR to the directory containing a CMake configuration file for roslint. The file will have one of the following names:
roslintConfig.cmake roslint-config.cmake
Call Stack (most recent call first): nmea_navsat_driver/CMakeLists.txt:4 (find_package)
CMake Error at nmea_navsat_driver/CMakeLists.txt:23 (roslint_python): Unknown CMake command "roslint_python".
I don't know what roslint_DIR is, and can't find anything about it online, but I did try searching my computer for both roslintConfig.cmake and roslint-config.cmake (no results for either). Anyone know what could be going wrong/how to fix it?
Originally posted by mysteriousmonkey29 on ROS Answers with karma: 170 on 2014-08-14
Comment by mysteriousmonkey29 on 2014-08-14:
I'm not sure if I modified everything I should have from your example, but I tried
rosdep install --from-paths ~/catkin_ws/src --ignore-src --rosdistro hydro -y
And it told me "ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: toro: Cannot locate rosdep definition for [ncurses++]" Ncurses is something I'm using in another executable in the same project (that I don't care about anymore). I tried commenting out the CMakeLists reference to that executable, but it didn't change the error.
Comment by Gary Servin on 2014-08-14:
another option is to create another worskpace and clone only the gps driver there. Can you try that?
Alright, made a catkin_ws2 right next to the first one (had to check out the ros tutorials again). Then I added the path to my ROS_PACKAGE_PATH, cloned it into the src directory, and catkin_made. Unfortunately, I get exactly the same error.
Actually I get what you mean now. I ran the rosdep install line in my catkin_ws2 and it worked. Now catkin_make builds successfully and I can run the executable! So what exactly did that line do? I don't understand the --from-paths src and --ignore-src parts.
Comment by Gary Servin on 2014-08-15:
you can read what they mean in the installation guide from source for indigo (section 2.1.2).
Comment by mysteriousmonkey29 on 2014-08-19:
Ok, thanks!
did you tried checking the dependencies before catkin_make? for example,
rosdep install --from-paths src --ignore-src --rosdistro indigo -y
EDIT: Added second part from the comments.
Originally posted by Gary Servin with karma: 962 on 2014-08-14
Initialized a second catkin_ws, git cloned the package into the src directory, and ran the suggested line in it: rosdep install --from-paths ~/catkin_ws/src --ignore-src --rosdistro hydro -y
Then catkin built and the installation is complete.
