Hello everybody! I would like to create a map with gmapping with 10x10 cells dimension and that every cells are bigger than my robot. Is it possibile? which parameters of gmapping do I have to modify?
Originally posted by alex920a on ROS Answers with karma: 35 on 2014-08-13
Theoretically those:
~xmin (float, default: -100.0)
Initial map size
~ymin (float, default: -100.0)
Initial map size
~xmax (float, default: 100.0)
Initial map size
~ymax (float, default: 100.0)
Initial map size
~delta (float, default: 0.05)
Processing parameters (resolution of the map)
However, 10x10 is a VERY small map with a VERY rough solution. This sounds really odd. Especially with a resolution of let's say 0.5m (guessed robot size) you will get localization accuarcy at best in this magnitude which is not preferable.
Originally posted by dornhege with karma: 31395 on 2014-08-13
Comment by alex920a on 2014-08-13:
ok thanks! I will try:)
with those parametrs I have a very BIG map! Are you sure abot xmin,ymin,xmax,ymax?
Comment by dornhege on 2014-08-13:
You need to set them differently of course. These are just the defaults.
ok so I I want 10x10 cell I have to modify this way?:
xmax=10; ymax=10; xmin=-10 ymin=10;
That depends how large the cells are. The min/max values are in meters.
my robot is 1m big. I want to have my robot smaller than the cells
The cell size is called delta here.
Comment by alex920a on 2014-08-14:
is it delta in meters?
Comment by dornhege on 2014-08-14:
yes .
ok thanks! so if i want cells 1m big do I have to set delta =1?
