good day everyone.
I'm curious (actually in desperation) on why i'm not able to see
/camera/rgb/image_raw/compressed
node when I launch up..
roslaunch turtlebot_bringup 3dsensor.launch
and output from lsusb and lsusb -t.
I'm using an Asus Xtion Pro Live camera.
Im working on a turtlebot-android project on Ubuntu 12.04, ROS Hydro which has a Teleop app on Play Store. As of now, I'm able to successfully control my turtlebot using the VirtualJoystick but I'm unable to receive the camera view.
The image view is subscribing to:
but my 3dsensor.launch does not show
node in the terminal when i launch.
Any help will be greatly appreciated. Thank you :)
my rostopic hz /camera/rgb/image_raw/compressed
$ rostopic hz /camera/rgb/image_raw/compressed
subscribed to [/camera/rgb/image_raw/compressed]
average rate: 28.921
    min: 0.022s max: 0.061s std dev: 0.00743s window: 25
average rate: 29.368
    min: 0.019s max: 0.061s std dev: 0.00667s window: 55
average rate: 29.599
    min: 0.000s max: 0.061s std dev: 0.00720s window: 85
average rate: 29.601
    min: 0.000s max: 0.061s std dev: 0.00738s window: 115
average rate: 29.474
    min: 0.000s max: 0.061s std dev: 0.00683s window: 144
^Caverage rate: 29.666
    min: 0.000s max: 0.061s std dev: 0.00734s window: 153
my rosnode list
$ rosnode list
/android/camera_view
/android/virtual_joystick
/app_manager_sr1_ThinkPad_T430_3169_1412817678
/app_manager_sr1_ThinkPad_T430_3169_1481506645
/app_manager_sr1_ThinkPad_T430_3169_1618152413
/app_manager_sr1_ThinkPad_T430_3169_178461068
/app_manager_sr1_ThinkPad_T430_3169_758011786
/app_manager_sr1_ThinkPad_T430_3169_759738930
/app_manager_sr1_ThinkPad_T430_3169_859751585
/camera/camera_nodelet_manager
/camera/depth_metric
/camera/depth_metric_rect
/camera/depth_points
/camera/depth_rectify_depth
/camera/depth_registered_rectify_depth
/camera/disparity_depth
/camera/disparity_registered_hw
/camera/driver
/camera/points_xyzrgb_hw_registered
/camera/rectify_color
/camera/rectify_ir
/dashboard
/depthimage_to_laserscan
/diagnostic_aggregator_sr1_ThinkPad_T430_3169_225580819
/gateway
/gateway_hub
/mobile_base_nodelet_manager_sr1_ThinkPad_T430_3169_876265176
/pairingApplicationNamePublisher
/pairing_master
/robotNameResolver
/rosout
/rviz_1407977575449025588
/zeroconf/zeroconf_avahi
my rosnode info /android/camera_view
~$ rosnode info /android/camera_view
Node [/android/camera_view]
Publications:
 * /rosout [rosgraph_msgs/Log]
Subscriptions:
 * /turtlebot/application/camera/rgb/image_color/compressed_throttle [unknown type]
Services: None
contacting node http://192.168.1.33:56155/ ...
Pid: 19165
Connections:
 * topic: /rosout
    * to: /rosout
    * direction: outbound
    * transport: TCPROS
my output from $ lsusb
   $ lsusb
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 002: ID 15d1:0000
Bus 003 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1d27:0601
Bus 001 Device 004: ID 0a5c:21e6 Broadcom Corp.
Bus 001 Device 005: ID 04f2:b2db Chicony Electronics Co., Ltd
my output from $ lsusb -t
   $ lsusb -t
1-1.4:1.2: No such file or directory
1-1.4:1.3: No such file or directory
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
    |__ Port 1: Dev 2, If 0, Class=comm., Driver=cdc_acm, 12M
    |__ Port 1: Dev 2, If 1, Class=data, Driver=cdc_acm, 12M
    |__ Port 2: Dev 3, If 0, Class=vend., Driver=ftdi_sio, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
    |__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/8p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
    |__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/6p, 480M
        |__ Port 2: Dev 3, If 0, Class=vend., Driver=usbfs, 480M
        |__ Port 2: Dev 3, If 1, Class=audio, Driver=snd-usb-audio, 480M
        |__ Port 2: Dev 3, If 2, Class=audio, Driver=snd-usb-audio, 480M
        |__ Port 4: Dev 4, If 0, Class=vend., Driver=btusb, 12M
        |__ Port 4: Dev 4, If 1, Class=vend., Driver=btusb, 12M
        |__ Port 4: Dev 4, If 2, Class=vend., Driver=, 12M
        |__ Port 4: Dev 4, If 3, Class=app., Driver=, 12M
        |__ Port 6: Dev 5, If 0, Class='bInterfaceClass 0x0e not yet handled', Driver=uvcvideo, 480M
        |__ Port 6: Dev 5, If 1, Class='bInterfaceClass 0x0e not yet handled', Driver=uvcvideo, 480M
Here is my terminal when i launch the 3dsensor.launch
   $ roslaunch turtlebot_bringup 3dsensor.launch
... logging to /home/sr1/.ros/log/1b32e44a-234d-11e4-8f3e-6c881460500c/roslaunch-sr1-ThinkPad-T430-9170.log
Press Ctrl-C to interrupt
started roslaunch server http://192.168.1.28:53668/
SUMMARY
PARAMETERS
 * /camera/camera_nodelet_manager/num_worker_threads
 * /camera/depth_rectify_depth/interpolation
 * /camera/depth_registered_rectify_depth/interpolation
 * /camera/disparity_depth/max_range
 * /camera/disparity_depth/min_range
 * /camera/disparity_registered_hw/max_range
 * /camera/disparity_registered_hw/min_range
 * /camera/driver/auto_exposure
 * /camera/driver/auto_white_balance
 * /camera/driver/color_depth_synchronization
 * /camera/driver/depth_camera_info_url
 * /camera/driver/depth_frame_id
 * /camera/driver/depth_registration
 * /camera/driver/device_id
 * /camera/driver/rgb_camera_info_url
 * /camera/driver/rgb_frame_id
 * /depthimage_to_laserscan/output_frame_id
 * /depthimage_to_laserscan/range_min
 * /depthimage_to_laserscan/scan_height
 * /rosdistro
 * /rosversion
NODES
  /camera/
    camera_nodelet_manager (nodelet/nodelet)
    depth_metric (nodelet/nodelet)
    depth_metric_rect (nodelet/nodelet)
    depth_points (nodelet/nodelet)
    depth_rectify_depth (nodelet/nodelet)
    depth_registered_rectify_depth (nodelet/nodelet)
    disparity_depth (nodelet/nodelet)
    disparity_registered_hw (nodelet/nodelet)
    driver (nodelet/nodelet)
    points_xyzrgb_hw_registered (nodelet/nodelet)
    rectify_color (nodelet/nodelet)
    rectify_ir (nodelet/nodelet)
    depthimage_to_laserscan (nodelet/nodelet)
ROS_MASTER_URI=http://IP_OF_TURTLEBOT:11311
core service [/rosout] found
process[camera/camera_nodelet_manager-1]: started with pid [9188]
[ INFO] [1407977548.225724317]: Initializing nodelet with 4 worker threads.
process[camera/driver-2]: started with pid [9209]
process[camera/rectify_color-3]: started with pid [9225]
process[camera/rectify_ir-4]: started with pid [9239]
Warning: USB events thread - failed to set priority. This might cause loss of data...
process[camera/depth_rectify_depth-5]: started with pid [9254]
process[camera/depth_metric_rect-6]: started with pid [9268]
[ INFO] [1407977548.991024359]: Device "1d27/0601@1/3" with serial number "1403060204" connected
process[camera/depth_metric-7]: started with pid [9293]
process[camera/depth_points-8]: started with pid [9307]
process[camera/depth_registered_rectify_depth-9]: started with pid [9358]
process[camera/points_xyzrgb_hw_registered-10]: started with pid [9389]
process[camera/disparity_depth-11]: started with pid [9403]
process[camera/disparity_registered_hw-12]: started with pid [9419]
process[depthimage_to_laserscan-13]: started with pid [9433]
[ INFO] [1407977578.705534860]: Starting color stream.
[ INFO] [1407977578.855011729]: using default calibration URL
[ INFO] [1407977578.855178763]: camera calibration URL: file:///home/sr1/.ros/camera_info/rgb_PS1080_PrimeSense.yaml
[ INFO] [1407977578.855309751]: Unable to open camera calibration file [/home/sr1/.ros/camera_info/rgb_PS1080_PrimeSense.yaml]
[ WARN] [1407977578.855391432]: Camera calibration file /home/sr1/.ros/camera_info/rgb_PS1080_PrimeSense.yaml not found.
[ INFO] [1407977578.972041790]: Starting depth stream.
[ INFO] [1407977587.912021800]: Stopping color stream.
[ INFO] [1407977588.924851214]: Stopping depth stream.
Originally posted by syaz nyp fyp on ROS Answers with karma: 167 on 2014-08-07
/camera/rgb/image_raw/compressed is a topic, not a node. Topics don't appear in the roslaunch output.
With the 3dsensor.launch file running, you should be able to confirm that a node is publishing on this topic with:
rostopic info  /camera/rgb/image_raw/compressed
This will also tell you if any nodes are subscribed to this topic.
If your nodes and publishing and subscribing to the topic, but the subscriber isn't seeing any data, it may be useful to confirm that data is being published with:
EDIT
The output from your 3dsensor.launch file suggests that there is something wrong with the setup for your sensor. You can try plugging it into a USB2 if you have one, and checking the device permissions. The output of lsusb and lsusb -t may be useful here.
EDIT
It looks like you're using an Asus from within a virtual machine. Given that the openni sensors tend to be sensitive to USB issues and use most of the USB bus bandwidth, I'm not too surprised that it doesn't work. (It probably isn't supported by your virtualization software)
Originally posted by ahendrix with karma: 47576 on 2014-08-07
Comment by syaz nyp fyp on 2014-08-07:
@ahendrix, i was mistaken about the nodes and topic. I'm aware of that now. thank you.
i did the rostopic info /camera/rgb/image_raw/compressed
and the publisher itself is camera_nodelet_manager. not /camera/rgb/image_raw/compressed.
Comment by ahubers on 2014-08-07:
Additionally, as far as I know, trying to display /camera/rgb/image_raw/compressed will not work, as that stream is compressed. What you can instead do is
rosrun image_transport republish compressed in:=camera/rgb/image_raw out:=/output_topic_name,
and subscribing to that output topic...
Comment by ahendrix on 2014-08-07:
@syaz-nyp-fp - can you add the output from lsusb and lsusb -t to your question?
Comment by syaz nyp fyp on 2014-08-10:
@ahendrix, appreciate your time. have updated the question.
Comment by ahendrix on 2014-08-11:
Sorry - It looks like you tried to add the output from lsusb, but it looks like it failed to post or something.
Comment by syaz nyp fyp on 2014-08-12:
@ahendrix, I'm sure i did post. I've had my mates to view it too.
Comment by ahendrix on 2014-08-12:
On my system, running the lsusb command gives me output like:
$ lsusb
Bus 003 Device 002: ID 138a:0017 Validity Sensors, Inc.
Bus 003 Device 003: ID 17ef:1010 Lenovo
Bus 003 Device 004: ID 8087:07dc Intel Corp.
Bus 003 Device 005: ID 0451:8044 Texas Instruments, Inc.
Bus 003 Device 006: ID 17ef:100f Lenovo
Bus 003 Device 007: ID 045e:0750 Microsoft Corp. Wired Keyboard 600
I don't see anything like that in your question.
@ahendrix, i've re-edit and repost. have it the question now. :)
Comment by syaz nyp fyp on 2014-08-13:
@ahendrix, i have 2 turtlebots here with me. One is on Virtual Machine (for testing) and the other, Native Ubuntu. Both running on 12.04 ROS Hydro. Both is giving me the same result despite trying lots of steps.
I just can't able to find out what the prob is here..
The
rosrun info /camera/rgb/image_raw/compressed
result triggers me that it has for sure something gotta do w/ the publisher
It displays the wrong publisher:
instead of
Comment by ahendrix on 2014-08-13:
That is the correct publisher for that topic. The problem is that the driver isn't able to talk to your device, probably because you're trying to use the openni drivers from inside a virtual machine.
Also note that there are no subscribers listed. If you android app was working properly, it would be listed in the list of subscribers for the camera topic.
@ahendrix, There are no subscriber listed because the app is not subscribing to camera_nodelet_manager under the topic of /camera/rgb/image_raw/compressed. And as i said, I've another turtlebot on a Ubuntu (not virtual machine) and same problem rise up.
May i know if it's the ASUS itself? Because the Teleop app actually uses Kinect. Can this cause the issue?
Please pick ONE configuration to troubleshoot; preferably the real turtlebot.
Have you tried running rostopic hz /camera/rgb/image_raw/compressed as I suggested to confirm that images are published?
on the machine that is NOT virtual machine.
i did the following steps:
  1. roscore
  2. roslaunch turtlebot_bringup 3dsensor.launch
  3. rocon_launch turtlebot_bringup bringup.concert
  4. connect my android app to turtlebot.
It is able to connect. i can control using joystick. but camera not showing up
@ahendrix, i did rostopic hz /camera/rgb/image_raw/compressed and yup, it has the
average rate 29.670 min: 0.019s max: 0.067s std dev: 0.00511s window:204
continuously..
Ok; that probably means that the driver is running and publishing images properly, but your android app isn't subscribing. You should be able to find the node name in rosnode list and then use rosnode info to list which topics it's subscribing to.
@ahendrix, ive edited the question and the rosnode list is in it. :)
As, you can see, the android app is actually subscribing to the /turtlebot/application/camera/rgb/image_color/compressed_throttle topic. The next debugging step is to figure out where that topic is supposed to be coming from, and run it.
Unfortunately, I'm not very familiar with the app infrastructure on the turtlebot, so I don't have any pointers for you.
Comment by syaz nyp fyp on 2014-08-14:
@ahendrix, Thank you for your time. Couldn't appreciate more to have you replying and guiding me. Thanks :)
