Quick question, how do I publish a multiarray? I use rostopic a lot, and its tremendously helpful. One thing I was never able to figure out, was how publish a multiarray(I also wasn't able to find a post on it).
This is the format it provides:
rostopic pub /topic_name std_msgs/Float32MultiArray "layout:
  dim:
  - label: ''
    stride: 0
  data_offset: 0
data:
- 0"
That can publish a single element multiarray, but I couldn't figure out how to add another element on that array.
I've tried...
  dim:
  - label: ''
    stride: 0
  data_offset: 0
data:
- [0.0, 1.0]"
and a bunch of other variants, but nothing works. If someone can help with the syntax, that would be appreciated!
Originally posted by pwong on ROS Answers with karma: 447 on 2014-08-05
3 Answers 3
See this answer:
$ rostopic pub /topic_name std_msgs/Float32MultiArray "layout:
dim:
  - label: ''
    stride: 0
  data_offset: 0
data: [0.0, 1.0, 2.0]"
Originally posted by BennyRe with karma: 2949 on 2014-08-06
Post score: 5
Comment by pwong on 2014-08-07:
Thank you!
Comment by atomoclast on 2016-09-13:
Hello, I tried this a Int16MultiArray message and got this error out:
ERROR: No field name [dim]
Args are: [layout.dim layout.data_offset data]
Any idea what it could be?
Comment by Cerin on 2017-03-26:
@atomoclast: Your message is malformed. You need to put dim inside the layout key, like this answer shows. e.g. {layout: {dim: [...]}, ...}, not {dim: [...]}.
@atomoclast
i have an Messege Generated with works
 rostopic pub /speed std_msgs/Int16MultiArray "layout:
   dim: []
   data_offset: 0
 data: [10, 100]"
the Importen part ist the make an multi line CMD, and not convert the input to an single line
Originally posted by duck-development with karma: 1999 on 2017-01-18
Comment by jayess on 2017-03-26:
YAML strings can be mulit-line or single-line. http://wiki.ros.org/YAML%20Overview
For me none of this worked, I always have an error like
"field data[] must be an integer type" (or a float if it's a float array of course.).
How I achieved to send multiple value was to set one value a a line preceding by a hyphen.
exemple:
rostopic pub /modbus_wrapper/input std_msgs/Int32MultiArray "layout:
  dim:
  - label: ''
    stride: 0
  data_offset: 0
data:
- 0
- 1
- 3
