I succed finally to launch my move_base.launch file. And when with rviz I tried to tell where the robot is in the map, with the 2d Pose Estime, i got this message :
Failed to transform initial pose in time (Lookup would require extrapolation into the future.  Requested time 1407222627.317546291 but the latest data is at time 1407222627.301636934, when looking up transform from frame [map] to frame [base_link])
I think that there is a link with my previous problem http://answers.ros.org/question/187967/groovy-how-to-link-scan-to-base_link/
This is my view_frames image description
My local costmap is :
local_costmap:
  global_frame: /odom
  robot_base_frame: base_link
  update_frequency: 5.0
  publish_frequency: 2.0
  static_map: false
  rolling_window: true
  width: 6.0
  height: 6.0
  resolution: 0.05
My global costmap is global_costmap: global_frame: /map robot_base_frame: base_link update_frequency: 5.0 static_map: true
The link beetween map and /odom is done in the move_base.launch file :
  <node pkg="tf" type="static_transform_publisher" name="odom_map_broadcaster" args="0 0 0 0 0 0 /map /odom 100" />
When I launched roswtf i got this error
Loaded plugin tf.tfwtf
No package or stack in context
Static checks summary:
No errors or warnings
Beginning tests of your ROS graph. These may take awhile...
analyzing graph...
... done analyzing graph
running graph rules...
... done running graph rules
running tf checks, this will take a second...
... tf checks complete
Online checks summary:
Found 3 warning(s).
Warnings are things that may be just fine, but are sometimes at fault
WARNING The following node subscriptions are unconnected:
 * /amcl:
   * /tf_static
   * /clock
   * /initialpose
   * /scan
 * /robot_state_publisher:
   * /joint_states
 * /rpid_velocity:
   * /rwheel
 * /diff_tf:
   * /lwheel
   * /rwheel
 * /map_server:
   * /clock
 * /odom_map_broadcaster:
   * /clock
 * /move_base:
   * /move_base_simple/goal
   * /tf_static
   * /clock
 * /lpid_velocity:
   * /lwheel
WARNING These nodes have died:
 * mark2_arduino-2
WARNING Received out-of-date/future transforms:
 * receiving transform from [/robot_state_publisher] that differed from ROS time by 1407396264.96s
 * receiving transform from [/diff_tf] that differed from ROS time by 1407396264.45s
Found 1 error(s).
Update The new tf view_frames
image description
Originally posted by Moda on ROS Answers with karma: 133 on 2014-08-05
Comment by l0g1x on 2014-08-07:\
  1. are you by chance using your system clock to set time stamps to any of your transform messages? Your computers system clock isn't same as ros::time since ros time starts from the year 1970. That could be one explanation for the huge time difference it is telling you you are having.
2) I know you said you are building your own map when I asked if you are using bagged data, but are you sure your not just using recorded wheel odometry and scan data? And building your own map off of replaying that bag file?
Whether you are using bag data or not, try setting the use_sim_time parameter to true for your mapping node. This will use the ros simulation time rather then whatever time you are currently using. If that still doesn't work, send me a e-mail and we will figure out things from there.
Comment by Moda on 2014-08-09:
Sorry it doesn't work
Comment by l0g1x on 2014-08-11:
email me and i will help you figure this out. krgebis AT gmail DOT com
Comment by ahendrix on 2014-08-21:
Setting use_sim_time on a real robot WILL mess things up.
Comment by Moda on 2014-08-22:
No sorry, even without use_sim_time, i have the very same error
4 Answers 4
Which frame are you publishing position estimates in? You should make sure that the rviz 2D pose estimate tool is set to publish position estimates in the map frame.
UPDATE
The complaint receiving transform from [/robot_state_publisher] that differed from ROS time by 1407396264.96s suggests that you have some nodes which are using sim time, and some which are not. You absolutely SHOULD NOT have the /use_sim_time parameter set on a real robot.
Originally posted by ahendrix with karma: 47576 on 2014-08-20
Comment by Moda on 2014-08-20:
How can I check that pose estimate is publish in the right frame?
However, when I made a pose estimate, this had been published in the terminal : [ INFO] [1408552044.916830213]: Setting pose: 0,161 2,930 2,263 [frame=map] So I think that I'm publishing in the right frame
Comment by ahendrix on 2014-08-20:
The rivz "Tool Properties" panel allows you to configure the 2D pose estimate tool. You should be able to echo the /initialpose topic to confirm which frame is being used.
When I made rostopic echo /initialpose i got this
header:
  seq: 3
  stamp:
    secs: 0
    nsecs: 0
  frame_id: map
pose:
  pose:
    position:
      x: 0.281967163086
      y: 3.63046169281
      z: 0.0
orientation: x: 0.0 y: 0.0 z: 0.912528928351 w: 0.409012169652 covariance: [0.25, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.25, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.06853891945200942]
So, is this good?
That looks good. Are you sure that the message you're receiving is actually causing problems? Do you know which node it's coming from?
When I made pose estimate i got this
[ WARN] : Failed to transform initial pose in time (Lookup would require extrapolation into the future.  Requested time 1408553779.104397674 but the latest data is at time 1408553779.067091941, when looking up transform from frame [map] to frame [base_link])
And my robot is not seen in rviz, not in is real place. Rviz says that the robot is out of the map. The map is a real one. And then, I can not send the robot somewhere, with 2D Nav Goal, in rviz, However, I don't know where the issues really come from
Sorry even without use_set_time, I have the very same error
The message is
   [ WARN] [1408693106.228430308]: Failed to transform initial pose in time (Lookup would require extrapolation into the future.  Requested time 1408693106.228264741 but the latest data is at time 1408693106.204777002, when looking up transform from frame [map] to frame [base_link])
Comment by ahendrix on 2014-08-22:
That is NOT the same error mentioned in your question - note that the time difference is now < 1 second, where before it was > 1400000000 seconds.
You may want to check that the clocks are synchronized between your control PC and your robot.
Comment by Moda on 2014-08-25:
How can I do that
What is your local and global costmap parameters set to?
Also can you post a snippet of your code for where you publish the Odom-> map transform, as well as the baselink -> Odom transform?
It will help me better diagnose your problem.
Originally posted by l0g1x with karma: 1526 on 2014-08-05
Comment by l0g1x on 2014-08-05:
Are you using bagged data? (rosbag play)?
Comment by Moda on 2014-08-05:
No I build my own map.
Comment by l0g1x on 2014-08-06:
Have you tried decreasing your rate at which the transform happens between then children of base_link and base_link itself? instead of 50 hz, turn them all to 10 as well so that your que doesnt get filled up. Try that and let me know
also after everything is running, run "roswtf" in your terminal and let me know if there is any errors
I'm not sure how you transform from Odom to map within your mapping node, but that is definitely where your error is occurring. Here is a similar post: http://answers.ros.org/question/164911/move_base-and-extrapolation-errors-into-the-future/
Comment by Moda on 2014-08-06:
But he is trying to change a file named goal_functions.cpp and I don't have it, so what to do?
I guess the issue is broadcast frequency of odom. Publishing it with 50Hz will probably work.
It doesn't work, i still have the same error, even if i changed the publishing rate I posted my updated tf view_frames
