Hello There!
I am having a hard time to get the Navigation Stack running on a robot (Turtlebot).
I am Using AMCL for Autonomous Navigation in the View of Rviz.
when i Launch
roslaunch turtlebot_navigation amcl_demo.launch map_file:=/home/sr1/Blk-S-Level-1.yaml
I get a warning
[ WARN] [1407204643.804135907]: Waiting on transform from base_footprint to map to become available before running costmap, tf error:
when i launch Rviz, roslaunch turtlebot_rviz_launchers view_navigation.launch
i dont see anything only black Background. under Global Setting i see Error, No tf.
sorry, haven't got karma>20, so cannot post images
Please, can someone help me out? If anything else is needed, I will gladly post it later.
Thanks in advance :)
Originally posted by vinod9910 on ROS Answers with karma: 61 on 2014-08-04
Comment by Moda on 2014-08-05:
Now you have enough karma In Gloabl setting try to put /map
I had the same problem because when i've saved my map I did it in the tmp directory (like in the tutorial) and then manually transfer it to other directory.
If you did it too i advise you to copy the files again to tmp load it , and save it in other location by: rosrun map_sever map_saver -f /...your directory goes here.../you_map_name
Originally posted by tal_eldar with karma: 33 on 2015-08-05
in my Globlal setting i have set is as /Map
i have the photo below of the probem.
image description
Originally posted by vinod9910 with karma: 61 on 2014-08-05
Comment by Moda on 2014-08-06:
I think you have two topic with the same name map. Try to check it
Comment by l0g1x on 2014-08-06:
What is your log for amcl saying? Did it load the map correctly? Can you add the param output= "screen" to the (out can change screen to log and post the log if you want too
