Hello! I am learning ROS recently . I have some questions about velodyne package:
  1. After I run "$roslaunch velodyne_pointcloud 32e_points.launch calibration:=/home/llm/catkin_ws/src/velodyne_pointcloud/params/32db.yaml" in the terminal , which .cpp file in src/conversions/ was executed ?
  2. I notice that in the file convert.cpp , "output_" publish a "outMsg" (velodyne_rawdata::VPointtCloud::Ptr) in line 78,but in line 31 ,the "output_" advertise "sensor_msgs::PointCloud2" message ,I can not understand this code.
  3. I am focused on this one . I created a node to subscribe the topic "velodyne_points" , and I want to extract the information of the points's XYZ coordinate value from the topic , but I can not understand the message type "sensor::PointCloud2", what should I do?
Looking for you reply ! Thank you very much !
Originally posted by Lau on ROS Answers with karma: 47 on 2014-08-03
  1. That launch file runs the cloud nodelet in a velodyne_nodelet manager process. The cloud nodelet is built using cloud_nodelet.cc and convert.cc.
  2. The constructor must advertise the topic before the callback can publish to it.
  3. An example of reading the individual points in the message is here in RingColors::convertPoints, a method that reads /velodyne_points and publishes a colored cloud containing the same points in /velodyne_rings.
EDIT: To run the Ring Colors nodelet, you can create your own launch file, something like this (untested):
<include file="$(find velodyne_pointcloud)/launch/32e_points.launch" />
<node pkg="nodelet" type="nodelet" name="ring_colors_nodelet"
      args="load velodyne_pointcloud/RingColorsNodelet velodyne_nodelet_manager" />
Originally posted by joq with karma: 25443 on 2014-08-03
Comment by Lau on 2014-08-04:
Thank you .
  1. For the second question , I mean that the "outMsg" is not a type "sensor_msgs::PointCloud2" message . In my previous study , I noticed that the types should be same like the code(copied from the tutorials) listed : { ros::Publisher chatter_pub = n.advertise<std_msgs::String>("chatter", 1000); ... std_msgs::String msg; ... chatter_pub.publish(msg); }
  2. For the third question. If I want to run the ringcolors_nodelet.cc and colors.cc and read the point's message , should I creat a .launch file like the cloud_nodelet.launch and add it to 32e_points.launch?
Comment by joq on 2014-08-04:
pcl_ros and pcl_conversions provide a callback interface for the PointCloud2 message, converting it to a PCL point cloud, which the code can conveniently manipulate.
Thank you ! now I can read the individual point now !
Comment by joq on 2014-08-05:
If this answers your question, please click the check mark.
