Hai,
  1. I am new to linux and ROS. I am using 12.04 (32 bit) in a 64 bit machine. I tried to install ros-hydro package. After fetching (sudo apt-get install) 90-95% package, download stops by giving an error:
unable to fetch some archives maybe run apt-get update or try with fix-missing
Earlier, I installed same package in a 32 bit machine without any error.
  1. Links that are failed to open in terminal window are accessible through web browser in UBUNTU O.S.
  2. I am accessing internet through co-axial cable modem (does n't have any proxy settings)
Thanks, kota
Originally posted by jkota on ROS Answers with karma: 21 on 2014-07-30
It's possible that you hit the repository at a bad time.
Try running sudo apt-get update and then retrying your installation.
Originally posted by ahendrix with karma: 47576 on 2014-07-31
Comment by tfoote on 2014-08-14:
I've had trouble a couple times in the last week accessing all the ubuntu repositories. It's unusual but does happen sometimes.
On top of Hendrix's suggestion (meaning after you do an apt-get update) you might also want to try this:
apt-get --download-only
in order to force Ubuntu to download all of your stuff first; No install will take place. If the operation fails here, then, yes, it is a repository error. If it succeeds, move to the regular apt-get install and check if the error happens again.
Honestly, Hydro on Ubuntu 12.04 is VERY vanilla. Shouldn't fail at all.
Just in case, post you entire apt-get command, so we know what you are installing.
Originally posted by ccapriotti with karma: 255 on 2014-07-31
