Hello,
Is there a way to modify the local planner so that the robot would always move within a certain distance of the Global Path. And in this case, if an obstacle appeared on the map and covered the global path, and re-planning required the robot to move outside this predefined distance of the original global path, the robot should just stop.
Thanks
Originally posted by ROSCMBOT on ROS Answers with karma: 651 on 2014-07-29
Comment by David Lu on 2014-07-29:
Which local planner are you using?
Comment by ROSCMBOT on 2014-07-29:
I'm using ROS default local planner (DWA or Trajectory Rollout)
With DWA, you can bias the robot toward staying on the global path by increasing the path_distance_bias parameter.
http://wiki.ros.org/dwa_local_planner#Trajectory_Scoring_Parameters
Originally posted by David Lu with karma: 10932 on 2014-07-29
Comment by ROSCMBOT on 2014-07-30:
Thanks, but this is not exactly what I want to do. Your suggested way will force the robot to stop if an obstacle appears on the global path, but I want the robot to replan if there is a path within a certain distance of the global path, and stops otherwise
Comment by David Lu on 2014-07-30:
That kind of behavior requires more complex tuning of move_base, and the functionality for that is not yet available.
Maybe I should open another thread for this question, but is it possible to manually update the costmap so everything outside the certain distance of the global path become obstacles, so that the robot never moves to those areas?
