When i launch move_base.launch, I got this :
ERROR: cannot launch node of type [tf/static_transform_publisher]: can't locate node [static_transform_publisher] in package [tf]
ERROR: cannot launch node of type [amcl/amcl]: can't locate node [amcl] in package [amcl]
However I already have done : sudo apt-get install ros-hydro-amcl and sudo apt-get install ros-hydro-tf
Originally posted by Moda on ROS Answers with karma: 133 on 2014-07-29
Comment by BennyRe on 2014-07-29:
What happens if you do roscd tf?
Comment by Moda on 2014-07-29:
/opt/ros/hydro/share/tf$
and for amcl : /opt/ros/hydro/share/amcl
Comment by sterlingm on 2014-07-29:
Can you post your ROS_PACKAGE_PATH environment variable?
What is my ROS_PACKAGE_PATH ? the path for the catkin_ws folder? If yes it is /home/lempereur/catkin_ws and the path for the hydro is /opt/ros/hydro/
Do "env | grep ROS" and you will see it. It is the path where ROS looks for your packages. But if roscd takes you where you listed it is probably fine. Do "ls /opt/ros/hydro/lib/tf" and see if it lists the static_transform_publisher executable.
My ROS_PACKAGE_PATH is ROS_PACKAGE_PATH=/opt/ros/hydro/share:/opt/ros/hydro/stacks
when I maid ls /opt/ros/hydro/lib/tf I get bullet_migration_sed.py static_transform_publisher tf_change_notifier tf_echo tf_empty_listener tf_monitor tf_remap view_frames
Ok static_transform_publisher exists. Do ls -l /opt/ros/hydro/lib/tf to see if it's executable.
Comment by Moda on 2014-08-01:
I got this : -rwxr-xr-x 1 root root 18872 juin 17 10:57 static_transform_publisher
And even for amcl I have this : -rwxr-xr-x 1 root root 620296 juil. 23 21:42 amcl
Comment by dido_yf on 2014-12-18:
hello, I have the same problem with you. Did you solve this problem? Could you tell me how?
I deleted all the files from my workspace, and reinstall everythink. And it solves my error. Thank you for your help BennyRe and Sterlingm. However, i got this error :
Waiting on transform from base_link to map to become available before running costmap, tf error:
[ WARN] [1406882852.669591743]: No laser scan received (and thus no pose updates have been published) for 1406882852.669489 seconds.  Verify that data is being published on the /scan topic.
I already faced this issue in groovy, and i was unable to found a solution. http://answers.ros.org/question/187967/groovy-how-to-link-scan-to-base_link/
Originally posted by Moda with karma: 133 on 2014-08-01
