Trying to compile ROS from source on Ubuntu 14 (trusty) on NVIDIA Jetson tk1. I'm stucked on this problem:
==> Processing catkin package: 'qt_gui_cpp'
==> Building with env: '/home/ubuntu/ros_catkin_ws/install_isolated/env.sh'
Makefile exists, skipping explicit cmake invocation...
==> make cmake_check_build_system in '/home/ubuntu/ros_catkin_ws/build_isolated/qt_gui_cpp'
==> make -j1 -l1 in '/home/ubuntu/ros_catkin_ws/build_isolated/qt_gui_cpp'
[ 76%] Built target qt_gui_cpp
[ 84%] Running SIP generator for qt_gui_cpp_sip Python bindings...
  File "/home/ubuntu/ros_catkin_ws/install_isolated/share/python_qt_binding/cmake/sip_configure.py", line 41, in <module>
    subprocess.check_call(cmd)
  File "/usr/lib/python2.7/subprocess.py", line 535, in check_call
    retcode = call(*popenargs, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 522, in call
    return Popen(*popenargs, **kwargs).wait()
  File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
make[2]: *** [sip/qt_gui_cpp_sip/Makefile] Error 1
make[1]: *** [src/qt_gui_cpp_sip/CMakeFiles/libqt_gui_cpp_sip.dir/all] Error 2
make: *** [all] Error 2
<== Failed to process package 'qt_gui_cpp':
  Command '/home/ubuntu/ros_catkin_ws/install_isolated/env.sh make -j1 -l1' returned non-zero exit status 2
Reproduce this error by running:
==> cd /home/ubuntu/ros_catkin_ws/build_isolated/qt_gui_cpp && /home/ubuntu/ros_catkin_ws/install_isolated/env.sh make -j1 -l1
Command failed, exiting.
ANY IDEA?
Originally posted by formica on ROS Answers with karma: 61 on 2014-07-25
Comment by jacksonkr_ on 2016-04-08:
Make sure you have multiverse and universe sources available. Check out my answer below.
UPDATE
I now have experimental binary builds of Indigo available for Trusty armhf: http://wiki.ros.org/indigo/Installation/UbuntuARM
ORIGINAL ANSWER
On my Jetson tk1, this executes /usr/bin/sip, which is part of the sip-dev package. Do you have sip-dev installed?
I found out which executable it's trying to run by reading the sip_configure.py script and then running the following python snippet:
from PyQt4 import pyqtconfig
cfg = pyqtconfig.Configuration()
print cfg.sip_bin
Originally posted by ahendrix with karma: 47576 on 2014-07-25
