I have managed to solve most of my problems, but the missing thing with me is with the CMakeLists.txt of the hand_pub. (BTW should I edit it for the hand_urdf ??) I have added the following in my CMakeLists.txt, is there any thing I should add?
find_package(catkin REQUIRED COMPONENTS roscpp rospy std_msgs) catkin_package() include_directories(include ${catkin_INCLUDE_DIRS}) > add_executable(state_publisher > state_publisher.cpp) > target_link_libraries(state_publisher > ${catkin_LIBRARIES})
Because I am getting an error when trying catkin_make. I am not sure if my cpp file is wrong or it is not able to compile at all.
my old post:
I have finished my URDF file and saved it in catkin_ws/src/hand/hand_urdf/urdf (its name is hand.urdf) I was able to open it in rviz using :
roslaunch urdf_tutorial display.launch model:=Hand.urdf gui:=True
(the current directory being the one stated above) and everything works and I can move the hand and everything using the state_publisher gui. Then I worked on the state_publisher, I did the state_publisher.cpp and saved it in catkin_ws/src/hand/hand_pub and wrote a launch file called display.launch and saved it in catkin_ws/src/hand/hand_pub/launch I think I have something wrong with my launch file which is:
My question is do I have something wrong with the directories? Do I have something wrong with my launch file? Most importantly how do I run everything together from terminal (I think that I have to run the launch file but what is the exact command for that) i.e. for the urdf I called roslaunch urdf_tutorial display.launch model:=Hand.urdf gui:=True.
Originally posted by Kaddoura on ROS Answers with karma: 1 on 2014-07-24
Comment by David Lu on 2014-07-25:
If you are getting an error, please post the error.
You also need to upload the urdf to the parameter server. Do this by adding the following line to your launch file.
<param name="robot_description" textfile="$(find hand_urdf)/urdf/hand.urdf" />
(assuming that I'm reading your directories correctly)
Originally posted by David Lu with karma: 10932 on 2014-07-24
Comment by Kaddoura on 2014-07-24:
Thank you for your help, now I am getting an error when compiling the state_publisher.cpp file using CMakeLists, please check my post after I edited it and see if you can help me.
