I am working with the XBee Network Example on the wiki (using ROS Hydro on Ubuntu 12.04 with Series 1 XBees) but I can't get further than setting up the XBees. Has anyone successfully got the example working? I get this error after entering the command
rosrun rosserial_xbee xbee_network.py /dev/ttyS0 1
RosSerial Xbee Network
Contacting Xbees : ['\x00\x01']
Exception in thread Thread-6:
File "/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner self.run()
**File "/usr/lib/python2.7/threading.py", line 504, in run self.__target(*self.__args, self.__kwargs)
File "/opt/ros/hydro/lib/python2.7/dist-packages/rosserial_python/SerialClient.py", line 426, in run if self.port.inWaiting() < 1:
AttributeError: FakeSerial instance has no attribute 'inWaiting'
Originally posted by cb92 on ROS Answers with karma: 11 on 2014-07-22
Comment by tonybaltovski on 2014-07-22:
What port is your xbee connected to?
Comment by cb92 on 2014-07-22:
/dev/ttyS0
I had a (mostly) working XBee network going with ROS Hydro. But when I upgraded to Indigo last night, I got this error immediately. I haven't found any solution yet Edit: I just removed all the ros-indigo-rosserial-* packages, and copied my old rosserial from Hydro to Indigo. Now working fine.
Originally posted by TimboInSpace with karma: 141 on 2014-09-25
