Hey guys,
I have a very frustrating problem using Ros Hydro on ubuntu 12.04. I have a Gazebo Simulation posting telemetry data and I use this in a node to create a tf-tree for the simulation.
Now I tried to combine my tf-tree with some static transform publishers and noticed that my transform from the c++ node which subscribes to the telemetry is using wall time. The statics transform publishers are using simulation time.
I searched the web, set use_sim_time to true and tried some other things but ros::Time::now() in my c++ code always returns wall time, while the static transform publisher use simulation time! This makes it impossible to use the transform together.
use_sime_time is set before launching any nodes, but my node launches before the /clock topic is available, looking into this next.
Originally posted by proprentnerl on ROS Answers with karma: 26 on 2014-07-22
Are you setting use_sim_time before starting the node in questions? Can you check if your node subscribes to the /clock topic?
Please update your question with this information.
Originally posted by demmeln with karma: 4306 on 2014-07-22
Comment by proprentnerl on 2014-07-22:
Yes use_sim_time is set before starting the node, it seems that my node starts before the /clock topic is available and than continues to use wall time instead of switching to simulation time. I will try waiting for the /clock topic before calling ros::Time::now() in my node.
Comment by ahendrix on 2014-07-22:
I believe ros::Time has an explicit method to wait for the simulated clock to be initialized.
See ros::Time::waitForValid()
Comment by Martin Günther on 2014-07-23:
@proprentnerl: I don't think your theory is correct. If use_sim_time is set, ros::Time::now() will return 0 until it receives the first /clock message, not walltime. This is also the condition that waitForValid() checks for, so that won't fix your problem.
The rospy implementation of tf has some horrible hacks (and bugs) involving walltime, but you mentioned using roscpp, so my guess is that @demmeln is right: your node is started before use_sim_time is set.
Problem solved.
use_sim_time was needed but lead to another problem. The main node was waiting for a service from a python node... when using use_sim_time the main node wouldn't detect the service as long as the /clock service was nit published... Our main node starts the simulation with the /clock service, so doing this first before waiting for the python node service fixed the problem... It seems that python nodes become unresponsive when use_sim_time is activated but no /clock topic is published even when they don't need ans ros::Time functions.
Originally posted by proprentnerl with karma: 26 on 2014-07-23
