Hello, I'm using a ROS driver for the ax2550 motor controller found here:
https://github.com/wjwwood/ax2550
(I couldn't figure out the actual download, so I just created my own project and copied the text into each file, then catkin_made. I don't think this is the source of my problems, since it compiled, and worked for a similar device driver that I got working just yesterday.)
I have plugged the device into a serial-->usb converter, which then goes into my computer. However, when I run the node using:
rosrun ax2550 ax2550_node /dev/ttyUSB0 (this is the port its connected to)
I get the following response:
[ INFO] [1405371811.620859117]: AX2550 connecting to port /dev/ttyUSB0
[ERROR] [1405371811.621207096]: Failed to connect to the AX2550: IO Exception (13): Permission denied, file /tmp/buildd/ros-hydro-serial-1.1.7-0precise-20140617-0339/src/impl/unix.cc, line 150.
[ INFO] [1405371811.621317396]: Will try to reconnect to the AX2550 in 5 seconds.
It looks like this is a permissions error (despite the fact that I am the administrator), but I don't know for sure and if it is I don't know how to change these permissions. Anyone got any ideas?
Thanks
New info:
I ran the line sudo chmod 777 /dev/ttyUSB0, which solved the error I was initially having. However, I am now encountering a new error when I try to run the node: [ INFO] [1405453884.235150040]: AX2550 connecting to port /dev/ttyUSB0 [ERROR] [1405453886.236099864]: Failed to connect to the AX2550: Synchronization Exception: did not receive an R/C message after reset, file /home/randy/catkin_ws/src/toro/src/ax2550.cpp, line 315. [ INFO] [1405453886.503068921]: Will try to reconnect to the AX2550 in 5 seconds. Any idea what could be causing this one?
Originally posted by mysteriousmonkey29 on ROS Answers with karma: 170 on 2014-07-14
Comment by gvdhoorn on 2014-07-15:
You can use 'git clone URL' to create a local copy of the repository (see also the 'HTTPS clone url' box at the bottom right on the repository page. You might benefit from following a tutorial on git(hub), such as http://readwrite.com/2013/09/30/understanding-github-a-journey-for-beginners-part-1.
Comment by mysteriousmonkey29 on 2014-07-15:
Thanks. I checked this out and it is a much easier method of installing github stuff
Comment by William on 2014-07-15:
@randylewis7 if you are still having trouble getting this to work you might update your question with new information.
Make sure you have dialout access. Try sudo chmod 766 /dev/YOURPORT. A colleague of mine had a similar issue.
Originally posted by tonybaltovski with karma: 2549 on 2014-07-14
That did the trick, thanks. I ran the line
sudo chmod 777 /dev/ttyUSB0, which solved the error I was telling you about initially. However, I am now encountering a new error when I try to run the node:
No need to sudo on the port. As tonybaltovski suggests you only need to be in the dialout group. I had a similar issue with the iRoomba create 2 and I fixed it by doing:
sudo adduser <your-username> dialout
and very,very,VERY important: don't forget to logout and login back on your machine for the changes to be applied :)
Originally posted by RagingBit with karma: 706 on 2016-10-20
Comment by EpicWolverine on 2017-01-04:
Thanks. This is a better solution than chmod-ing after every reconnect and a more secure solution than changing the permissions on the port in general.
