I use KDevelop 4.3.1 for ROS Groovy with ubuntu 12.04.
I try to open CMakeLists.txt on KDevelop to open ROS project, but it shows the error that says can't find ros/ros.h.
image description
How to set KDevelop for ROS properly?
Thank you very much~~
Originally posted by sam on ROS Answers with karma: 2570 on 2014-07-12
Comment by sam on 2014-07-13:
Thank you~ You are correct! When I run kdevelop on bash, the ros.h header is found. Please post it as an answer~^^
Have you tried starting KDevelop from within a shell where you have sourced your setup.bash?
Originally posted by gvdhoorn with karma: 86574 on 2014-07-12
Post score: 5
