Hey, so I need to compile my workspace every time I add it into my computer. This proves to be very time consuming. I would like to write a script that runs these commands:
roscd /directory/build
cmake ..
make
This is what I type into the terminal to compile all the directories and it works perfectly! But, when I tried just adding these commands to a script and running it I would get errors basically saying it didn't recognize the commands (i.e. roscd). I'm not sure if I'm supposed to source something so it will recognize the commands or something.
Any help is appreciated! George
Originally posted by GWall on ROS Answers with karma: 27 on 2014-07-09
Comment by allenh1 on 2014-07-09:
You have a good answer down there... But, I must ask... Why are you using cmake at all? With a catkin workspace, catkin builds (invoking CMake) all packages in the source directory in topological order. This is mainly for my own curiosity.
Comment by GWall on 2014-07-10:
Hey, thanks for your curiosity! When we started with ROS a catkin didn't exist. Then when it did we never made the transition, but we are planning on switching over pretty soon. Even with catkin I would like to have a script because its one less thing I need to setup when I install the system!
You need to source your ros workspace's startup script in your own script's instance for all of your package/stack names to be recognized by roscd.
Just add the following snippet before your commands:
source ~/ros_ws/devel/setup.bash
Replace ros_ws with the path to your workspace.
Originally posted by tgd with karma: 76 on 2014-07-09
Post score: 4
Comment by Martin Peris on 2014-07-09:
Not only that, but probably he also needs to source the ROS setup script before sourcing the workspace's startup script: source /opt/ros/<your_ros_distro>/setup.bash
worked like a charm! Thanks!! @tgd
Comment by RDaneelOlivaw on 2018-04-17:
Mini bash script to test this:
#!/bin/bash
echo "Ros Test START"
source /opt/ros/kinetic/setup.bash
source /home/user/catkin_ws/devel/setup.bash
roscd
pwd
roscd my_package
pwd
echo "Ros test END"
