I installed ros-hydro-openni-launch to my Odroid-U3. When I ran
roslaunch openni_launch openni.launch
it successfully streams as I can see the topics send average at 30 fps via the command
rostopic hz /camera/rgb/image_rect_color
However, once I subscribe also to
rostopic hz /camera/depth_registered/hw_registered/image_rect_raw
Both of the subscribers do not receive any more images as shown below..
Is this a bug? I also downloaded the latest commit of openni_launch and openni_camera in the github. But it was still the same... But they DO WORK alone. But subscribing to both of them fails....
image description
Originally posted by Xegara on ROS Answers with karma: 52 on 2014-07-08
Looking at Openni.launch shows:
  <!-- Use OpenNI's factory-calibrated depth->RGB registration? -->
  <arg name="depth_registration" default="false" />
meaning you need to instead run
roslaunch openni_launch openni.launch depth_registration:=true
Although you are reporting that depth_registration works without setting that argument to be true, which is odd. Regardless maybe this will fix the issue? worth a shot...
Originally posted by ahubers with karma: 301 on 2014-08-05
