Hello,
I am new to ROS and I would like to know whether it is possible to get the graph visualization of ROS nodes like in rqt_graph in a file format which can be further modified manually (nodes rearranged, etc.) and printed properly?
Thank you very much myro
EDIT: I simply want a graph file of my current running nodes in order to print the visualization on paper in a proper format. For that, I need some graph description file where i can visually move nodes in order to fit them on a A4-paper. (It also makes sense for documenting the "stack". I cannot influence the layout in rqt_graph.) I do not want to change my actual running nodes/topics. It just would be nice to get a file describing the nodes-graph which can be postprocessed.
Originally posted by myro on ROS Answers with karma: 3 on 2014-07-05
rqt_graph has a button (in the upper right corner) to save to a file (specifically, a DOT graph file). The dot file is a text file that you can open with any editor and modify as you wish, then run through dot (part of graphviz software) to put it another format.
Originally posted by kramer with karma: 1470 on 2014-07-06
Comment by myro on 2014-07-09:
oops. how could i miss those. thanks a lot.
