Hello,
I installed the driver for two Flea3 Pointgrey cameras whose accessibility are (successfully) verified via:
rosrun pointgrey_camera_driver list_cameras
12062824 12062828
Now "starting" one of those cameras with
roslaunch pointgrey_camera_driver camera.launch camera_serial:=12062824
I would like to display my images with
rosrun image_view image_view image:=/camera/image
but I receive the following error code:
[ERROR] [1404221648.972130708]: Client [/image_view_1404220593387350082] wants topic /camera/image to have datatype/md5sum [sensor_msgs/Image/060021388200f6f0f447d0fcd9c64743], but our version has [wfov_camera_msgs/WFOVImage/807d0db423ab5e1561cfeba09a10bc88]. Dropping connection. [ERROR] [1404221696.898906591]: Client [/image_view_1404221696410391988] wants topic /camera/image to have datatype/md5sum [sensor_msgs/Image/060021388200f6f0f447d0fcd9c64743], but our version has [wfov_camera_msgs/WFOVImage/807d0db423ab5e1561cfeba09a10bc88]. Dropping connection.
It seems like the camera.launch script publishes the images in a message format which is not known to image_view.
As I am a beginner to Linux as well as ROS I would like to ask for some tips how to publish my images (or edit camera.launch) in a certain way, eg. under the topic "left_camera/image".
Also how would I take a first step in displaying my images from the camera?
Thank you!
Originally posted by mister_kay on ROS Answers with karma: 238 on 2014-07-01
Comment by asdfgf on 2016-06-28:
Can I Know how did you resolve this issue ?
When you go to run image_view, you have to view the "raw" image format using rosrun image_view image_view image:=/camera/image_raw.
Let me know if this works and if you are able to view both at once. I'm having issues attempting to view both streams simultaneously at the moment.
Originally posted by JustBenj with karma: 16 on 2016-02-24
Comment by Sam6 on 2017-08-24:
Hi, when I run the above command, a blank window opens up. I am able to get some data when I run 'rostopic echo /camera/image' but not able to view it using image_view. What could it be that am doing wrong?
