Hi All, I need to use the rostopic pub command in phyton shell script: In c++ the command is: rostopic pub -r 5 /uav1/sug_cmd_vel geometry_msgs/Twist -- '[0.0, 0.2, 0.0]' '[0.0, 0.0, 0.0]'
In python I entered like this: ['rostopic', 'pub', '-r 5', '/uav1/sug_cmd_vel', 'geometry_msgs/Twist', '--','['0.0, 0.2,0.0', '0.0,0.0,0.0']' Also, I tried several other combinations but still getting syntax error. Can anyone help with this issue?. Thanks a lot
Originally posted by Robert1 on ROS Answers with karma: 63 on 2014-06-29
If you are using python why do you want to use the following command?
This command is meant to be used directly from the command line
You could just use rospy directly
import rospy
import roslib
roslib.load_manifest('your_package')
from geometry_msgs.msg import Twist
rospy.init_node('dummy')
# publish to cmd_vel
p = rospy.Publisher('/uav1/sug_cmd_vel', Twist)
# create a twist message, fill in the details
twist = Twist()
twist.linear.x =0.0;
twist.linear.y = 0.2;
twist.linear.z = 0.0;
twist.angular.x = 0;
twist.angular.y = 0;
twist.angular.z = 0;
p.publish(twist)
don't forget to add geometry_msgs as dependency to your package in the manifest.xml.
Originally posted by Mehdi. with karma: 3339 on 2014-07-02
