Hi! I want to call a native function from my rosjava node which basically does some processing work and returns a variable of type double which is then finally published by the publisher. Can anyone please help me out?
Thanks.
Originally posted by Arjav on ROS Answers with karma: 1 on 2014-06-28
Comment by ahendrix on 2014-06-30:
The android documentation for the native function you're trying to call should probably tell you how to call it from Java.
@Arjav this is a general Android question, so Android documentation is probably the best place to look for the answer,
Try starting here: https://developer.android.com/ndk/guides/index.html. That should help you to bind a Java method to native code, and also to compile and link the native code into your app.
Originally posted by jubeira with karma: 1054 on 2018-02-15
