Hello, I am using ROS Hydro on Ubuntu 12.04. When calling MoveIt! Commander's (Python) move_group.compute_cartesian_path() method, the return value is always the current joint configuration. The code looks something like this.
eef_link = "gripper_palm_link"
waypoints = []
waypoints = group.get_random_pose(eef_link)
poses.append(copy.deepcopy(pose.pose))
(plan, fraction) = group.compute_cartesian_path(waypoints, eef_step=0.01, jump_threshold=0.0, avoid_collisions=True)
My robot starts off in the home position which is essentially joint positions set to all zeros. After the call to compute_cartesian_path() the resultant joint trajectory look like this:
header:
  seq: 20
  stamp:
    secs: 0
    nsecs: 0
  frame_id: base_link
joint_names: ['arm_joint_1', 'arm_joint_2', 'arm_joint_3', 'arm_joint_4', 'arm_joint_5']
    positions: [0.001216606411158061, 0.0001137616260065144, -0.0006536926007463251, 0.0025598054398985326, 0.0007543179427678126]
    velocities: [0.0, 0.0, 0.0, 0.0, 0.0]
    accelerations: [0.0, 0.0, 0.0, 0.0, 0.0]
    effort: []
    time_from_start:
      secs: 2
      nsecs: 0
The positions are essentially zero (i.e., the home position). I suspect that the call to group.get_random_pose(eef_link) is returning an invalid end effector position, but I don't know why it would do that. Any help would be appreciated.
Originally posted by Rick C NIST on ROS Answers with karma: 28 on 2014-06-27
Comment by Rabe on 2014-06-27:
My guess would be that you might have screwed up in the Setup-Assistant or your urdf? Did you check the limits in the urdf?
Comment by Rick C NIST on 2014-06-27:
I am using the Kuka youbot URDF unmodified which I am assuming is correct. The setup assistant could be the problem or maybe that I am not setting the end effector link? One interesting data point is that if I call group.set_pose_target(pose) and then group.plan(), I get a valid trajectory from Moveit.
I presume that the pose with all joints at 0 is basically the arm completely stretched out -- thus it as the limit of it's workspace. Even if the random pose is valid, there may not be a cartesian path between the points since the starting point is near the limits of the workspace. Have you tried a different starting point that is somewhat centered in the workspace of the arm?
Originally posted by fergs with karma: 13902 on 2014-06-27
Joints at all 0 means the home position (i.e. all scrunched up) Here is a picture of the home position: http://www.kuka-labs.com/NR/rdonlyres/17026737-5839-4346-9939-5D012133E9FE/0/service_youBot_Features.jpg.
I would have thought that get_random_pose() would give me a valid pose.
