I am migrating a packet to catkin. It contains a test. The test runs successfully like this:
rostest my_navigation_test my_test_4_cob.test
but when i add
add_rostest(launch/my_test_4_cob.test)
to the equivalent CMakeLists.txt and call catkin_make test I get:
catkin_make test
Base path: /home/aub-ch/ros/hydro_mynavigationtest
Source space: /home/aub-ch/ros/hydro_mynavigationtest/src
Build space: /home/aub-ch/ros/hydro_mynavigationtest/build
Devel space: /home/aub-ch/ros/hydro_mynavigationtest/devel
Install space: /home/aub-ch/ros/hydro_mynavigationtest/install
#### Running command: "make cmake_check_build_system" in "/home/aub-ch/ros/hydro_mynavigationtest/build"
#### Running command: "make test -j8 -l8" in "/home/aub-ch/ros/hydro_mynavigationtest/build"
Running tests...
Test project /home/aub-ch/ros/hydro_mynavigationtest/build
    Start 1: _ctest_my_navigation_test_rostest_launch_my_test_4_cob.test
1/1 Test #1: _ctest_my_navigation_test_rostest_launch_my_test_4_cob.test ...***Failed    5.64 sec
0% tests passed, 1 tests failed out of 1
Total Test time (real) =   5.66 sec
The following tests FAILED:
      1 - _ctest_my_navigation_test_rostest_launch_my_test_4_cob.test (Failed)
Errors while running CTest
make: *** [test] Error 8
Invoking "make" failed
It is a bit hard to debug as it gives no feedback about what is really happening at all.
Any ideas?
Can you explain to me what the line '_ctest_my_navigation_test_rostest_launch_my_test_4_cob.test' means? Does it expect the launchfile to be called like this? (which it isn't)
Originally posted by ct2034 on ROS Answers with karma: 862 on 2014-06-24
Comment by ct2034 on 2014-06-24:
This might has been my fault, because i messed up my multiple workspaces. But I'll check it
Use catkin_make run_tests, rather than just test.
See the how-to run tests documentation.
Originally posted by joq with karma: 25443 on 2014-06-24
Thank you. This helps a lot as I can see the test output
Comment by William on 2014-06-24:
You can also call catkin_test_results to get a summary of tests.
Do you mind checking out my follow up question, too: http://answers.ros.org/question/174807/rostest-arguments-in-cmakelists/
