On Ubuntu 14.04 Trusty I recently installed Ros Indigo using apt-get and the turtlebot packages from source following the instructions on turtlebot/indigo/instillation tutorial (but using rosdep install --from-paths src -i -y -r for the turtlebot modules). When I try to launch the turtlebot simulator using
roslaunch turtlebot_gazebo turtlebot_empty_world.launch
the turtlebot does not show in the gazebo window nor does the majority of the expected topics get posted (ie any of the /camera/* topics or /odom topic).
I'm using Gazebo 2.2.2, Ubuntu 14.04 and ROS Indigo I've sourced my the indigo setup.bash as well as the ones for the rocon, kobuki, and turtlebot modules from the instilation tutorial above. After starting the program the gazebo window will open and you can pan/zoom but none of the models will show on the screen, including any that I add after the program starts.
Below is the output of running roslaunch turtlebot_gazebo turtlebot_empty_world.launch
... logging to /home/charlie/.ros/log/6fa28384-f9a2-11e3-b032-54271e5d091b/roslaunch-charlie-FANG-2014-28176.log
Press Ctrl-C to interrupt
started roslaunch server http:// charlie-FANG-2014:60719/
SUMMARY
PARAMETERS
 * /bumper2pointcloud/pointcloud_radius: 0.24
 * /cmd_vel_mux/yaml_cfg_file: /home/charlie/tur...
 * /depthimage_to_laserscan/output_frame_id: /camera_depth_frame
 * /depthimage_to_laserscan/range_min: 0.45
 * /depthimage_to_laserscan/scan_height: 10
 * /robot_description: <?xml version="1....
 * /robot_state_publisher/publish_frequency: 30.0
 * /rosdistro: <...>
 * /rosversion: <...>
 * /use_sim_time: True
NODES
    bumper2pointcloud (nodelet/nodelet)
    cmd_vel_mux (nodelet/nodelet)
    depthimage_to_laserscan (nodelet/nodelet)
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    laserscan_nodelet_manager (nodelet/nodelet)
    mobile_base_nodelet_manager (nodelet/nodelet)
    robot_state_publisher (robot_state_publisher/robot_state_publisher)
    spawn_turtlebot_model (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [28191]
ROS_MASTER_URI=http:// localhost:11311
setting /run_id to 6fa28384-f9a2-11e3-b032-54271e5d091b
process[rosout-1]: started with pid [28204]
started core service [/rosout]
process[gazebo-2]: started with pid [28228]
/opt/ros/indigo/lib/gazebo_ros/gzserver: 5: [: Linux: unexpected operator
process[gazebo_gui-3]: started with pid [28234]
/opt/ros/indigo/lib/gazebo_ros/gzclient: 5: [: Linux: unexpected operator
process[spawn_turtlebot_model-4]: started with pid [28242]
Gazebo multi-robot simulator, version 2.2.2
Copyright (C) 2012-2014 Open Source Robotics Foundation.
Released under the Apache 2 License.
http:// gazebosim.org
Msg Waiting for master
Msg Connected to gazebo master @ http:// 127.0.0.1:11345
Msg Publicized address: 192.168.2.3
[ INFO] [1403396186.795938010]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1403396186.799826284]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
process[mobile_base_nodelet_manager-5]: started with pid [28281]
[ INFO] [1403396187.766250320, 0.030000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
Warning [gazebo.cc:215] Waited 1seconds for namespaces.
process[cmd_vel_mux-6]: started with pid [28415]
process[bumper2pointcloud-7]: started with pid [28495]
process[robot_state_publisher-8]: started with pid [28542]
Segmentation fault (core dumped)
[gazebo-2] process has died [pid 28228, exit code 139, cmd /opt/ros/indigo/lib/gazebo_ros/gzserver /home/charlie/turtlebot/turtlebot/src/turtlebot_simulator/turtlebot_gazebo/worlds/empty.world __name:=gazebo __log:=/home/charlie/.ros/log/6fa28384-f9a2-11e3-b032-54271e5d091b/gazebo-2.log].
log file: /home/charlie/.ros/log/6fa28384-f9a2-11e3-b032-54271e5d091b/gazebo-2*.log
process[laserscan_nodelet_manager-9]: started with pid [28620]
process[depthimage_to_laserscan-10]: started with pid [28947]
[gazebo_gui-3] process has finished cleanly
log file: /home/charlie/.ros/log/6fa28384-f9a2-11e3-b032-54271e5d091b/gazebo_gui-3*.log
The above is slightly modified to add a space between http:// and the name of the link to allow me to post the output above.
Originally posted by Charlie Murphy on ROS Answers with karma: 76 on 2014-06-21
Comment by tfoote on 2014-06-22:
TurtleBot packages haven't been released or tested on indigo yet. You're getting a segfault which suggests a memory issue. If you can run it in gdb to get a backtrace we could try to help you remotely. Otherwise you'll probably need to wait for it to be tested and released. PS if you can also provide the steps to reproduce someone might have a moment to test your problem specificcally.
Comment by Charlie Murphy on 2014-06-23:
Thank you, I'm actually unsure how to run roslaunch turtlebot_gazebo turtlebot_empty_world.launch command in gdb.
Comment by koenlek on 2014-06-25:
same issue here. @Charlie, it might also help to report this as an issue on the github of for example turtlebot_simulator (which contains turtlebot_gazebo).
There are still some issues with Gazebo and Indigo when using a URDF, see https://github.com/ros/rosdistro/issues/4633 for the details.
Originally posted by fergs with karma: 13902 on 2014-06-25
Comment by Charlie Murphy on 2014-06-25:
Hi thanks for the answer. I just came across this as well after posting an issue on the turtlebot_gazebo github.
I've figured out how to get this to work as a sort of semi-fix until the official debians are finalized and released. As fergs mentioned the problem is indeed with incompatabilities with ROS Indigo Gazebo and URDF. The temporary fix is to install Gazebo from source. This then lets gazebo use the urdf library that comes packaged with trusty.
Here are the steps I took from a fresh Ubuntu 14.04 install:
Install gazebo 2.2 from source. (I did the optional stage/player libraries as well) Install ros-indigo-desktop-full using apt-get Install ros turtlebot packages from source (only available option currently).
Use instructions found at: http://gazebosim.org/wiki/2.2/install http://wiki.ros.org/indigo/Installation/Ubuntu http://wiki.ros.org/turtlebot/Tutorials/indigo/SourceInstallation
Originally posted by Charlie Murphy with karma: 76 on 2014-07-10
