I'm trying to experiment on ROS to improve myself. I'm running ROS Groovy on Ubuntu 12.04 LTS. I have an analog Sharp sensor (4-30 cm range) connected to an Arduino Mega 2560. I'm using rosserial_arduino library, and the code in the arduino converts sensor data to cm and publishes on topic "/range_data".
I'm trying to write a node that is subscribed to the topic /range_data and publishes a boolean data to another topic "/order" with respect to the value of sensor data. I want to publish "0" when the sensor data is lower than 15 cm and "1" when higher.
My sharp listener code:
#include "ros/ros.h"
#include "sensor_msgs/Range.h"
#include "std_msgs/Bool.h"
float range = -1;
void rangeCallback(const sensor_msgs::Range::ConstPtr& range_data)
range = range_data->range;
ROS_INFO("I heard: [%f]", range);
ros::init(argc, argv, "sharp_listener");
ros::NodeHandle n;
ros::Subscriber sub = n.subscribe("range_data", 1000, rangeCallback);
ros::Publisher pub = n.advertise<std_msgs::Bool>("order", 1000);
std_msgs::Bool order;
while (ros::ok())
while(range =! -1)
if(range>=4 && range<=15)
order.data = 0;
pub.publish(order);
else if(range>15)
order.data = 1;
pub.publish(order);
range = -1;
ros::spin();
return 0;
Order_listener code:
void orderCallback(const std_msgs::Bool::ConstPtr& msg)
ROS_INFO("%d", msg->data);
ros::init(argc, argv, "order_listener");
ros::NodeHandle n;
ros::Subscriber sub = n.subscribe("order", 1000, orderCallback);
ros::spin();
return 0;
Sharp_listener node is succesfully subscribed to range_data. But it doesn't seem to publish on topic order. I can see that the rqt_graph is true but nothing happens when I start order_listener node or directly rostopic echo.
Originally posted by emreay on ROS Answers with karma: 90 on 2014-06-19
Comment by gtm on 2016-03-30:
HI emreay! I have used your code and was trying to subscribe "order" topic on another arduino. i was not able to blink the led on arduino based on the massage received. I am new to ros programming can you please help me.
