Hi to all,
I would like to generate a ".deb" file to share my ROS code with other. I have heard about Bloom and another ways to generate ".deb" files. However, this is not a good solution for me, I only need a local manner to generate a ".deb" file to obfuscate my source code and thereby, my colleague could install and use it in his computer, without see the source. I only need to share my code with my colleague, no with the ROS community, because it is a very concrete (ad hoc) source code, is not valid for the rest of community.
Is there a "ROS" manner to compile my ROS package in a .deb file?
Edit (by @William):
The first step is correct, it generates a debian folder with rules and another files.
$ cd path/to/your/catkin/package
$ bloom-generate rosdebian --os-name ubuntu --os-version trusty --ros-distro indigo
Then, when i try to use the second command:
$ fakeroot debian/rules binary
I have problems with CMakeList.txt.
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- catkin 0.5.86
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:72 (find_package):
  Could not find a configuration file for package roscpp.
  Set roscpp_DIR to the directory containing a CMake configuration file for
  roscpp.  The file will have one of the following names:
    roscppConfig.cmake
    roscpp-config.cmake
  CMakeLists.txt:7 (find_package)
  Could not find a configuration file for package message_generation.
  Set message_generation_DIR to the directory containing a CMake
  configuration file for message_generation.  The file will have one of the
  following names:
    message_generationConfig.cmake
    message_generation-config.cmake
CMake Error at CMakeLists.txt:26 (add_message_files):
  Unknown CMake command "add_message_files".
dh_auto_configure: cmake .. -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_VERBOSE_MAKEFILE=ON -DCATKIN_BUILD_BINARY_PACKAGE=1 -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_PREFIX_PATH=/usr returned exit code 1
make[1]: *** [override_dh_auto_configure] Error 2
make: *** [binary] Error 2
The compiler, among other errors, does not recognize "add_message_files" command. Any idea?
Thank you very much for your help ;)
I am trying with a lot of configurations, but it doesn't work. I am sure that the solution is very simple. I attach my CMakelist.txt and package.xml, order that you may check the files.
CMakelist.txt
project(br_modbus)
## Find catkin macros and libraries
## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
## is used, also find other catkin packages
find_package(catkin REQUIRED COMPONENTS roscpp message_generation std_msgs genmsg)
## System dependencies are found with CMake's conventions
find_package(Boost REQUIRED COMPONENTS system)
## Uncomment this if the package has a setup.py. This macro ensures
## modules and global scripts declared therein get installed
# catkin_python_setup()
## Declare ROS messages and services ##
## Generate messages in the 'msg' folder
 add_message_files(
   FILES
   BrInputStatus.msg
## Generate services in the 'srv' folder
 add_service_files(
   FILES
   setOutput.srv
   setOutputEmpty.srv
   setOutputString.srv
   getOutput.srv
## Generate added messages and services with any dependencies listed here
 generate_messages(
   DEPENDENCIES
   std_msgs
## catkin specific configuration ##
## The catkin_package macro generates cmake config files for your package
## Declare things to be passed to dependent projects
## INCLUDE_DIRS: uncomment this if you package contains header files
## LIBRARIES: libraries you create in this project that dependent projects also need
## CATKIN_DEPENDS: catkin_packages dependent projects also need
## DEPENDS: system dependencies of this project that dependent projects also need
catkin_package(
#  INCLUDE_DIRS include
#  LIBRARIES br_modbus
  CATKIN_DEPENDS message_runtime
#  DEPENDS system_lib
## Build ##
## Specify additional locations of header files
## Your package locations should be listed before other locations
# include_directories(include)
  ${catkin_INCLUDE_DIRS}
#include/${PROJECT_NAME}
## Declare a cpp library
# add_library(br_modbus
#   src/${PROJECT_NAME}/ClassIOModbusDev.cpp
## Declare a cpp executable
add_executable(ClassIOModbusDev src/ClassIOModbusDev.cpp)
## Add cmake target dependencies of the executable/library
## as an example, message headers may need to be generated before nodes
add_dependencies(ClassIOModbusDev /usr/lib/libmodbus.so ${catkin_EXPORTED_TARGETS})
## Specify libraries to link a library or executable target against
target_link_libraries(ClassIOModbusDev /usr/lib/libmodbus.so ${catkin_LIBRARIES})
Package.xml
<?xml version="1.0"?>
<package>
  <name>br_modbus</name>
  <version>0.0.0</version>
  <description>The br_modbus package</description>
  <maintainer email="[email protected]">Jose Luis</maintainer>
  <license>TODO</license>
  <!-- The *_depend tags are used to specify dependencies -->
  <!-- Dependencies can be catkin packages or system dependencies -->
  <!-- Use build_depend for packages you need at compile time: -->
  <build_depend>message_generation</build_depend>
  <build_depend>libmodbus-dev</build_depend>
  <build_depend>genmsg</build_depend>
  <build_depend>roscpp</build_depend>
  <!-- Use run_depend for packages you need at runtime: -->
  <run_depend>message_runtime</run_depend>
  <run_depend>roscpp</run_depend>
  <!-- Use buildtool_depend for build tool packages: -->
  <buildtool_depend>catkin</buildtool_depend>
  <!-- The export tag contains other, unspecified, tags -->
  <export>
    <!-- You can specify that this package is a metapackage here: -->
    <!-- <metapackage/> -->
    <!-- Other tools can request additional information be placed here -->
  </export>
</package>
Originally posted by Jose Luis on ROS Answers with karma: 375 on 2014-06-17
Post score: 12
You can still use bloom to generate the source deb, from which you can build a binary deb:
This will create a folder debian with all of the file you need to build a debian. After that you should be able to call something like this:
To build the .deb file (according to this site: https://wiki.debian.org/BuildingAPackage).
Node that by using the bloom-generate rosdebian ... ROS debian generator, this will setup the package to install into /opt/ros/<rosdistro>. If you want it installed into /usr you can just use the normal debian generator, i.e. replace rosdebian with debian.
The other option is to just use checkinstall: https://help.ubuntu.com/community/CheckInstall which I believe can make .deb files out of anything which has an install rule.
Edit:
You will need to install all dependencies and source the appropriate setup file (usually /opt/ros/hydro/setup.bash) before running fakeroot ....
Edit:
You can try to use dpkg-buildpackage instead:
http://manpages.ubuntu.com/manpages/precise/man1/dpkg-buildpackage.1.html
I would just recommend using checkinstall.
Originally posted by William with karma: 17335 on 2014-06-17
Post score: 11
Comment by Jose Luis on 2014-06-20:
As you can see in the CMakelist.txt and package.xml files, I use my own messages and services in my package, this is a trouble for the generation of .deb, as seen in the above mistake:
Comment by VictorLamoine on 2018-09-10:
Calling bloom-generate rosdebian is usually enough, distribution and ROS version are guessed automatically.
Is using CPack a bad idea? It allows to generate debian packages easily, what would be the drawbacks?
