Dear Ros-users, I downloaded package youbot_navigation for ros-hydro. I compiled it with catkin_make without error but when I try to run the lowpass_filter get ERROR: cannot launch node of type [youbot_navigation_common/lowpass_filter]: can't locate node [lowpass_filter] in package [youbot_navigation_common] even if the node is correctly compiled with catkin_make:
[ 15%] Built target lowpass_filter
the launch file is: roslaunch youbot_navigation_local move_base_local.launch
The complete output of catkin_make is:
raffaele@raffaele:~/ros/hydro_node/catkin_ws$ catkin_make Base path: /home/raffaele/ros/hydro_node/catkin_ws Source space: /home/raffaele/ros/hydro_node/catkin_ws/src Build space: /home/raffaele/ros/hydro_node/catkin_ws/build Devel space: /home/raffaele/ros/hydro_node/catkin_ws/devel Install space: /home/raffaele/ros/hydro_node/catkin_ws/install
Running command: "make cmake_check_build_system" in "/home/raffaele/ros/hydro_node/catkin_ws/build" Running command: "make -j6 -l6" in "/home/raffaele/ros/hydro_node/catkin_ws/build" [ 0%] [ 0%] Built target std_msgs_generate_messages_cpp Built target std_msgs_generate_messages_lisp [ 0%] Built target std_msgs_generate_messages_py [ 7%] [ 23%] Built target listener Built target beginner_tutorials_generate_messages_lisp [ 30%] Built target lowpass_filter [ 46%] Built target beginner_tutorials_generate_messages_cpp [ 76%] Built target beginner_tutorials_generate_messages_py [ 76%] Built target beginner_tutorials_gencpp [ 76%] Built target beginner_tutorials_generate_messages [ 84%] Built target talker [ 92%] Built target add_two_ints_server [100%] Built target add_two_ints_client raffaele@raffaele:~/ros/hydro_node/catkin_ws$
Thank you!
Originally posted by Rahndall on ROS Answers with karma: 133 on 2014-06-13
Comment by al-dev on 2014-06-13:
Hi Rahndall, can you edit your post to give us the complete output of catkin_make? And which launch command are you using?
HI
try
# In your catkin workspace
$ cd ~/catkin_ws
$ source ./devel/setup.bash
and then run your program.
Originally posted by Hamid Didari with karma: 1769 on 2014-06-13
It works :) Thank you!
Originally posted by Rahndall with karma: 133 on 2014-06-17
