I'm trying to roslaunch ardrone_driver. I have installed the ardrone_autonomy and tum_ardrone packages. when i try to roslaunch ardrone_driver i get this message:
[ardrone_driver-1] process has died [pid 19905, exit code -11, cmd /opt/ros/hydro/ardrone_autonomy/bin/ardrone_driver __name:=ardrone_driver __log:=/home/michael/.ros/log/1b4dd950-f22c-11e3-a388-d0df9a5bc38d/ardrone_driver-1.log]. log file: /home/michael/.ros/log/1b4dd950-f22c-11e3-a388-d0df9a5bc38d/ardrone_driver-1*.log all processes on machine have died, roslaunch will exit shutting down processing monitor... ... shutting down processing monitor complete done
And if i leave it long enough it says:
Timeout when reading navdatas - resending a navdata request on port 5554
If someone knows any solution to this problem i would appreciate the help.
I'm using ROS Hydro on Ubuntu 12.04. The ardrone is an AR Drone 2.0 firmware 2.3.3
Originally posted by Michael Panayiotou on ROS Answers with karma: 61 on 2014-06-12
Which .launch file from ardone_autonomy did you try to launch?
Just to go over the basic, you start the driver with rosrun ardrone_autonomy ardrone_driver. Make sure your computer is connected to the drone's wi-fi.
Originally posted by samudra with karma: 36 on 2014-06-12
Comment by Michael Panayiotou on 2014-06-12:
WiFi is on and connected to ardrone.i tried rosrun ardrone_autonomy ardrone_driver and i get this:
http://s7.postimg.org/c8xb5atga/Screenshot_from_2014_06_12_15_56_50.jpg
I even tried to connect it to my iphone and update it to 2.4.8 but i get stuck as you can see at the picture above.
Comment by Rabe on 2014-06-12:
open up the launch file you are trying to launch in a text editor. You'll see, that it will launch a couple of other nodes. To further investigate which node excactly is dying, you have to open up a couple of terminals and launch each node one after another. Post your findings in your question
The other option might be to just open up the log file described in your output ;) Usually there is more detailed information there too
Comment by samudra on 2014-06-12:
The picture looks OK to me. Can you get data from the drone say, with rostopic echo ardrone/navdata? If you connect to the drone from your phone, disconnect your computer.
If you want an example for flying AR.Drone with ROS, there is this tutorial: http://robohub.org/tag/parrot-ar-drone-tutorial/
Comment by Michael Panayiotou on 2014-06-13:
i made this video to show you where is the problem. if anyone knows any solution to this i will appreciate the help. https://www.youtube.com/watch?v=q48v_KG5ToM
Comment by samudra on 2014-06-13:
After you get those lines of [INFO], open another terminal, run: "rostopic list". You should see /ardrone/navdata among the output. If you do, the driver works. If you run "rostopic pub -1 /ardrone/reset std_msgs/Empty" you should see the drone LEDs change to red (green if you do it again).
