I am implementing a ColorOcTree in OctoMap. Since the default in OctoMap is to build a heightmap, given by this piece of code in octomap_server/src/OctomapServer.cpp in OctomapServer::publishAll(const ros::Time& rostime):
        //create marker:
    if (publishMarkerArray){
      unsigned idx = it.getDepth();
      assert(idx < occupiedNodesVis.markers.size());
      geometry_msgs::Point cubeCenter;
      cubeCenter.x = x;
      cubeCenter.y = y;
      cubeCenter.z = z;
      occupiedNodesVis.markers[idx].points.push_back(cubeCenter);
      if (m_useHeightMap){
        double minX, minY, minZ, maxX, maxY, maxZ;
        m_octree->getMetricMin(minX, minY, minZ);
        m_octree->getMetricMax(maxX, maxY, maxZ);
        double h = (1.0 - std::min(std::max((cubeCenter.z-minZ)/ (maxZ - minZ), 0.0), 1.0)) *m_colorFactor;
        occupiedNodesVis.markers[idx].colors.push_back(heightMapColor(h));
I am seeking to change the height map into a per-voxel color Octomap.
From what is stated in the paper for octomap, I can use the child class of OcTree (ColorOcTree). From what I understand, ColorOcTree contains all the methods for OcTree, plus the average color information. So, To get a colored Octomap, rewrite OctomapServer.cpp from a OcTree based structure to an ColorOcTree structure.
My question is, in order to do this in OctomapServer.cpp, is this the correct method or is there some better way to construct per-voxel colored octomap?
EDIT: I finished changing OctomapServer.cpp and associated nodes to ColorOcTree, however I notice that the color information isn't inputted from the point cloud, as per this code in OctomapServer.cpp
It seems like it is converting a PointCloud2 cloud into a PointCloud.
void OctomapServer::insertCloudCallback(const sensor_msgs::PointCloud2::ConstPtr& cloud){
  ros::WallTime startTime = ros::WallTime::now();
  // ground filtering in base frame
  PCLPointCloud pc; // input cloud for filtering and ground-detection
  pcl::fromROSMsg(*cloud, pc);
The second question becomes, I need to extract RGB data from either PointCloud or PointCloud2, and have it in a float32 representation. Do I use PointXYZRGB instead of PointXYZ in reading the PointCloud (If so how?) Or is there some better way to do it?
EDIT2: I did change PointXYZ to PointXYZRGB and got the associated RGB Data. however, after saving that data into the ColorOcTree and trying to send the ColorRGBA message (also in float32, I did so by dividing each one of the RGB data by 255.0) to the Occupied_cells_vis_array, I get blue color only. Can anyone explain why it is only outputting blue voxels?
Originally posted by xuningy on ROS Answers with karma: 101 on 2014-06-10
Comment by AHornung on 2014-06-11:
Isn't there a version of OctomapServer for colored maps already in RGBD-SLAM?
OctomapServer is publishing blue voxels as visualization for occupied nodes by default, unless you enable the parameter for the height map coloring. Only then it will set a different color for each voxel.
Comment by xuningy on 2014-06-11:
Hi Armin, There is a OctomapServer for colored maps? I could not find it in the rgbdslam_freiburg directory. Can you be more specific? I realized your second comment is true, but in order to override it, is there any way? I already have extracted data from PC and i believe it is in the tree. How would I use it if I choose to modify OctomapServer.cpp? Thanks!
The line in RGBDSLAM package refers me to this repository, which is not the default repository in octomap_server (nor does the ros stack contains the color octomap nodes at all). Do you advise downloading this and using this package instead :https://code.google.com/p/alufr-ros-pkg/source/browse/branches/octomap_mapping_color/?r=1940#octomap_mapping_color%2Foctomap_server%2Fsrc? This is a deprecated package.
Comment by AHornung on 2014-06-12:
Here is a file called ColorOctomapServer.cpp in RGBDSLAM: https://code.google.com/p/alufr-ros-pkg/source/browse/trunk/rgbdslam_freiburg/rgbdslam/src/?r=4116
That code in the branches at alufr-ros-pkg is definitely outdated though.
Comment by xuningy on 2014-06-13:
Thanks Armin! I just ended up rewriting OctomapServer overall. Still need to address deprecated packages...
The repository octomap_mapping_color is mostly deprecated, thus the color octomap server wasn't usable in recent version of OctoMap. Wrote my own ColorOctomapServer.cpp and everything works.
Originally posted by xuningy with karma: 101 on 2014-06-11
Comment by Amine on 2015-02-04:
Hello I am searching for color Octomap code in ros hydro, you have any suggestions where I can find such code? Regards
