I might put a similar question on this web. As writing a subject, I want to understand how to write a code with OMPL to move a turtlebot. Now, I'm writing the code. I think global_planner with OMPL needs next steps.
1.isStateValid()
isStateValid() is a function to check if a position putting a sampler on a map is free space.
isStateValid() is a function to store information like free space and obstacle region.
2.makePlan()
makePlan() includes ob::PlannerPtr planner( og::RRT(ss.getSpaceInformation())), setStateValidityChecker() and so on.
On this article the contents I want to ask is following. isStateValid has to receive state of OMPL format instead of costmap, so my code is wrong. As I explain above, costmap has many information about an obstacle. So I think that I should use a costmap. How should I edit this code? or Could anyone tell me more information if I'm not correct?
   bool isStateValid(costmap_2d::Costmap2DROS* costmap_ros){
   costmap_ros_ = costmap_ros;
   costmap_ = costmap_ros_->getCostmap();
   if(costmap_ > 253)
        return false;
    return true;
Thank you in advance!
Error message
/home/ken/catkin_ws/src/navigation/ompl_planner_rrt/src/ompl_planner_rrt.cpp: In function ‘bool ompl_planner_rrt::isStateValid(costmap_2d::Costmap2DROS*)’:
/home/ken/catkin_ws/src/navigation/ompl_planner_rrt/src/ompl_planner_rrt.cpp:62:3: error: ‘costmap_ros_’ was not declared in this scope
I edited ompl_planner_rrt.h like a following.
namespace ompl_planner_rrt{
    class OMPLPlannerRRT : public nav_core::BaseGlobalPlanner {
       public:
           OMPLPlannerRRT();
           OMPLPlannerRRT(std::string name, costmap_2d::Costmap2DROS* costmap_ros);
           void initialize(std::string name, costmap_2d::Costmap2DROS* costmap_ros);
           bool makePlan(const geometry_msgs::PoseStamped& start,
                  const geometry_msgs::PoseStamped& goal,
                  std::vector& plan);
           ~OMPLPlannerRRT();
       private:
           double footprintCost(double x_i, double y_i, double theta_i);
           bool isStateValid(const ompl::base::State *state);
           bool interpolatePathPose2D(std::vector& path);
           void publishPlan(std::vector path);
           void OMPLStateSE2ToROSPose2D(const ompl::base::State* ompl_state, geometry_msgs::Pose2D& pose2D);
           void OMPLScopedStateSE2ToROSPose2D(const ompl::base::ScopedState scoped_state, geometry_msgs::Pose2D& pose2D);
           void ROSPose2DToOMPLScopedStateSE2(ompl::base::ScopedState& scoped_state, const geometry_msgs::Pose2D pose2D);
           void PoseToPose2D(const geometry_msgs::Pose pose, geometry_msgs::Pose2D& pose2D);
           void Pose2DToPose(geometry_msgs::Pose& pose, const geometry_msgs::Pose2D pose2D);
Linking CXX shared library /home/ken/catkin_ws/devel/lib/libompl_planner_rrt.so
[100%] Built target ompl_planner_rrt
But, I have no confidence if my program works normally.
Originally posted by Ken_in_JAPAN on ROS Answers with karma: 894 on 2014-06-10
Comment by Ken_in_JAPAN on 2014-06-10:
Anyone is about to tell me to study C++.
Comment by alfa_80 on 2014-06-10:
Have you declared "costmap_ros_" variable? I guess that variable is a class variable.
Thanks @alfa_80, I don't understand costmap_2d. I know that It consists of Layered costmap. But I don't know how to take out cost from costmap. I'm checking it.
I quote a sample code GeomPlanningSE2_PRM.cpp on the web( http://robotics.naist.jp/edu/text/?Robotics%2FOMPL#OMPLProgramming ). isStateValid in this cpp just sets free space and obstacle region. That means this doesn't have a function to check if free space is.
I guess that isStateValid() is necessary to store information of costmap. I need to know the way to transfer from costmap to statespace of OMPL format.
Comment by Ken_in_JAPAN on 2014-06-15:
I deleted my answer, because anyone denied my answer. I know the reason that I intend to use a code with a bug. I want to know an essential answer to move a turtlebot with OMPL.
Your reference to costmap_ros_ variable has not been declared. The format suggests it's a member variable, so if you're moving it to a different class that may be a problem.
Originally posted by osrf with karma: 26 on 2014-06-10
Thanks @osrf, I replaced isStateValid( ) to ompl_planner_rrt::OMPLPlannerRRT::isStateValid( ). So, error message has gone out.
