Hi,
I have the following code:
#include ....
using namespace sensor_msgs;
using namespace message_filters;
std::vector<boost::shared_ptr<capygroovy::Ticks const> > ticks;
ros::Time last = ros::Time::now();
void callback(const ImageConstPtr& msg,const ImageConstPtr& msg2,const capygroovy::TicksConstPtr& msg3)
    ticks = ticks_cache.getInterval(last,msg3->header.stamp);
int main(int argc, char** argv)
    ros::init(argc, argv, "db_creator_node");
    ros::NodeHandle nh;
    message_filters::Subscriber<capygroovy::Ticks> ticks_sub(nh,"/ticks",1);
    message_filters::Cache<capygroovy::Ticks> ticks_cache(ticks_sub,10);
    message_filters::Subscriber<Image> rgb_sub(nh,"/camera/rgb/image_rect",1);
    message_filters::Subscriber<Image> dpt_sub(nh,"/camera/depth/image_rect_raw",1);
    typedef sync_policies::ApproximateTime<Image, Image, capygroovy::Ticks> MySyncPolicy;
    Synchronizer<MySyncPolicy> sync(MySyncPolicy(10), rgb_sub, dpt_sub, ticks_sub);
    sync.registerCallback(boost::bind(&callback, _1, _2, _3));
    return 0;
That, of course, is wrong because I declare ticks_cache in the main and when I call the method getInterval() in the callback I get the error:
/home/dede/catkin_ws/src/db_creator/src/db_creator_node.cpp:24: error: ‘ticks_cache’ was not declared in this scope
I suppose that a nice solution would be to write a class with the message_filters as members but in order to initialize them you need to pass to their constructor the node handle and the topic names. The problem is that I really can't figure out how this could be done, so any help would be appreciated! Thanks!
Originally posted by schizzz8 on ROS Answers with karma: 183 on 2014-06-04
Without adding a class (which would be best) or globals, you can pass easily an extra parameter to your callback, something like this:
void callback(const ImageConstPtr& msg,const ImageConstPtr& msg2,const capygroovy::TicksConstPtr& msg3,
              message_filters::Cache<capygroovy::Ticks> &ticks_cache)
    sync.registerCallback(boost::bind(&callback, _1, _2, _3, ticks_cache));
    return 0;
It really is as simple as that!
BTW, to make classes easier to create, we use a template like this:
template <typename T>
int NodeMain(int argc, char **argv, std::string const &nodeName)
    ros::init(argc, argv, nodeName);
    ros::NodeHandle nh;
    ros::NodeHandle pnh("~");
    T a(nh, pnh);
    ros::spin();
    return EXIT_SUCCESS;
Now you just need:
class MyNode
private:
public:
    MyNode(ros::NodeHandle publicNodeHandle, ros::NodeHandle privateNodeHandle)
        sync.registerCallback(boost::bind(&callback, this, _1, _2, _3, ticks_cache));
    NodeMain<MyNode>(argc, argv, "MyNode");
We also have a slightly more complicated template for a nodelet, and it means we can use class MyNode as either a stand-alone node or a nodelet without any code changes.
Originally posted by KenYN with karma: 541 on 2019-11-05
I use the following code to use message filters inside a class
class SubscribeAndPublish
public:
SubscribeAndPublish():sync2(image_sub,image_sub2,500){
image_sub.subscribe(n, "/camera/color/image_raw", 1);
image_sub2.subscribe(n, "/camera/aligned_depth_to_color/image_raw", 1);
sync2.registerCallback(boost::bind(&SubscribeAndPublish::callback,this, _1, _2));
odom_pub = n.advertise<nav_msgs::Odometry>("RGBDodom", 50);
private:
    ros::NodeHandle n;
    ros::Publisher odom_pub;
    message_filters::Subscriber<Image> image_sub;
    message_filters::Subscriber<Image> image_sub2;
    TimeSynchronizer<Image, Image> sync2;
Originally posted by arminkazim with karma: 103 on 2019-11-05
Post score: 5
Comment by berk tepebag on 2020-03-23:
I also had to add Node:: before callback to make it work. Otherwise throws "ISO C++ forbids taking the address of an unqualified or parenthesized non-static member function to form a pointer to member function." error.
            sync.registerCallback(boost::bind(&Node::callback, this, _1, _2));
