Yesterday, I could navigate my turtlebot with eband_local_planner. but today, I can't move it. So, rviz says following warning.
[ WARN] [1401378967.283247030]: MessageFilter [target=map ]: Discarding message from [/move_base] due to empty frame_id. This message will only print once. [ WARN] [1401378967.283417501]: Invalid argument passed to canTransform argument source_frame in tf2 frame_ids cannot be empty [ WARN] [1401378998.796621804]: Invalid argument passed to canTransform argument source_frame in tf2 frame_ids cannot be empty [ WARN] [1401379032.819038628]: Invalid argument passed to canTransform argument source_frame in tf2 frame_ids cannot be empty
Does anyone have any idea to solve these warning?
After that, Eband_local_planner says that it can't make path as following
[ INFO] [1401378966.134403366]: Global plan set to elastic band for optimization [ERROR] [1401378967.110080798]: NO PATH! [ERROR] [1401378967.110401250]: Failed to get a plan from potential when a legal potential was found. This shouldn't happen. [ERROR] [1401378998.546064278]: NO PATH! [ERROR] [1401378998.614580138]: Failed to get a plan from potential when a legal potential was found. This shouldn't happen. [ WARN] [1401378998.734102440]: Clearing costmap to unstuck robot.
Originally posted by Ken_in_JAPAN on ROS Answers with karma: 894 on 2014-05-29
Comment by Ken_in_JAPAN on 2014-05-29:
My turtlebot moves with base_local_planner, even though same error and warning happens.
Comment by David Lu on 2014-06-13:
Can you use ros console to figure out which module these messages originate from?
